Anyone cut a long bed frame to a short bed?
Old Aug 8, 2013 | 07:57 AM
dirt track racer 81's Avatar
Default Anyone cut a long bed frame to a short bed?
Has anyone shortened a long bed frame down to fit a short bed?
Found a single cab long bed truck pretty damn cheap and buddy found a truck I can get a straight bed off of and any donor parts that ill need..
Old Aug 8, 2013 | 08:34 AM
Whitecrewcab's Avatar
Check out Stacy David's gearz. They did exactly that on the show.
Old Aug 8, 2013 | 10:29 AM
ZR1 DREAMING's Avatar
Richard, BigTex on here, did as well.
Old Aug 8, 2013 | 01:34 PM
BigTex's Avatar
Yeah, I did mine. Was a pretty easy task overall. The rear section of the frame slips into the front half and is welded around the edge. I cut out the factory welds, slid the rear frame section out, chopped off some of the front frame, slid the rear section back in and welded it up.
Here is before:
During: Notice how all the rear support braces and main suspension components are located on the rear frame section. That all just gets moved forward.
And after:
In the last pic you can see I removed the front spring bracket. After this pic, I moved the bracket forward on the frame about a foot (and up as far as I could to lower the rear more).
I had to adjust the front bed mount tabs a couple of inches. Brake lines and emergency brake cables were too long afterward, but that was an easy fix. Spare factory tank from a shortbed truck strapped right in.
Old Aug 8, 2013 | 02:13 PM
outlawz2004's Avatar
custm2500 did as well, not a good example to follow though. LOL
Old Aug 8, 2013 | 02:26 PM
03sierraslt's Avatar
Check with CAGRacing. Lol.
I bet he will provide a tutorial.
Old Aug 8, 2013 | 02:29 PM
Mangled03gmc's Avatar
Baltimore Whore
I can not believe you out of all people asked that question Tyler. LOL
Old Aug 8, 2013 | 02:32 PM
Phantom's Avatar
11 Second Club
**** factory framerails.
Backhalf ftw
Old Aug 8, 2013 | 05:08 PM
Hmmm.. I bet that's my best bet to on how to get information..
Old Aug 8, 2013 | 05:09 PM
Just tryin to get an idea.. Either that or just back half it..
