'99 6.0 crank/LQ9 block/TH400....WHAT FLEXPLATE????
Old May 12, 2008 | 09:27 PM
9 Second Club
Default '99 6.0 crank/LQ9 block/TH400....WHAT FLEXPLATE????
I am way up **** creek w/out a paddle here boys. I have a 6.0 block, the slightly longer 6.0 crank, TCI LS1 flexplate, and a fuddle stall for my TH400. Obviously, the flexplate sticks out too far for my starter.
WHAT FIXES THIS. I've tried several truck starters, and they are all the same. I've tried lots of machine work to compensate on the plate and converter but it still isn't solving anything.
Who has resolved this issue before????
Old May 12, 2008 | 10:04 PM
xlcooplx's Avatar
you'll have to use a shorter crank from 01+ engines.
Old May 12, 2008 | 10:11 PM
gao8302's Avatar
The longer crank was for the 80e right? Thats why the new ones have the spacer
Old May 13, 2008 | 12:14 AM
9 Second Club
Are you positive there is NO FLEXPLATE MADE that will work??? At all? There had to be a flexplate with this crank at somepoint.
Old May 13, 2008 | 12:18 AM
7845's Avatar
Banned
why dotn you find a starter for a 00 3/4 ton truck? it should be that simple. those starters are little longer. i also think i have a 00 flexplate from a ironhead motor lying around. let me check to see if its still around...possibly ship it to you for cost of shipping and gas to the drop off
Old May 13, 2008 | 10:07 AM
9 Second Club
We tried a few starters......all of the teeth are the same distance from the mounting holes.
Old May 13, 2008 | 12:02 PM
7845's Avatar
Banned
did you try a specific starter for that year? like i said ill look for the flexplate i have here. if i have it its yours like i stated.
it shouldnt be that hard to figure out tho. the iron crank is longer yes, but later models are same distance with a spacer. unless something is wrong with your build
Old May 13, 2008 | 05:54 PM
Truckshop's Avatar
is the flexplate on backwards? a starter for a 3/4 ton w/ a 80e should fit. if it doesn't then something is not put together correctly.
Old May 16, 2008 | 02:21 AM
hyeride00's Avatar
when i put the 80e in my 2000 (which from what i hear has the longer crank) i didnt have to mess with the starter at all....i went to GM and ordered the flexplate for the 3/4 ton for the 2000 model year...if i remember correctly, it came with a spacer?? I am not positive, but i think when i put it on, it looked like it was backwards, but it was actually the correct way to install it. its been 4 years, so my memory is a little shaddy
Old May 16, 2008 | 02:50 AM
jfman's Avatar
Some info on ls1tech
https://ls1tech.com/forums/showthrea...crankshaft+lq4
lukn4trbl355
Oct 21, 2015 11:19 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 04:22 PM
