65e Trans again or something else?
Old Apr 1, 2008 | 12:22 PM
  #21
fastnblu's Avatar
Originally Posted by built408
A 4L60 can be built to handle some power.. I dog the crap out of mine and it's still kickin. 603 rwhp and 701 rwtq and I'm at the track at least once a week with 12.5 wide tires..... Although myn is a regular cab 2wd and lighter than yours.. Either get somebody that knows how to build a 4L60 or go all out and get the 80.
Weight is not good for 60e. Built408, how long u been running w/above mentioned unit. How hard do you drive it on the street? I took an 89 RCLB, put in modded ImpySS LT1. Left in bone stock 700r4( 1 wk.). I know I said STOCK. Had built 60e(2 wks. sun gear, planetary broke off 5pcs.); same guy did but w/ upgraded planetary & 1 other upgrade...sun prolly. Built 60e #2 snapped input, destroyed 1 wk shy of a year. Said he wouldn't cover. It upshifted extremely hard(chirped em). But I should say my rearend blew & took trans. too. Soooo...prolly rear did most carnage, that time. Best guess on weight 4700#. Still can't afford to fix.
On the 04, I'll give FLT 1 shot at a 4l6xE. I plan on more power than older truck. If a built Level 5 goes, 4l80e will be the end all be all.
BlackSSS, I know blown trans.(s) gets $$$, particularly, if bought more than once. How hard do u beat on yours on street? I might forego FLT 65e, & go bite bullet for 80e. I usually go overkill for pc. of mind.
Old Apr 1, 2008 | 12:30 PM
  #22
BlackSSS's Avatar
Originally Posted by dewmanshu
don't get me wrong, not knocking the tuner. The best forget(overlook) a small thing. I have seen a spot in the in shift tables where all that was wrong was a higher mph in the downshift and a lower in the upshift. Only 2 cells wreaked havoc on that ride. If is always snapping your neck on the 1/2 then something is wrong, albeit tune, electronics, shift kit, whatever.
hey, no problem....ill get it and send it to ya
Old Apr 1, 2008 | 09:10 PM
  #23
FLT's Avatar
FLT
FormerVendor
Originally Posted by BlackSSS
WOW. So about where do you think the power cutoff is for a 65e sconsidering 5k + lb truck awd? So are these companies advertising 7-800hp cabable 65e trans hogwash?
IDK, message me a ballpark on me sending you a repaired 65e for tradein on an 80e....if possible or interested.
thanks
I feel that about 500-550 rwhp is about where the 4l6X will work for you guys. Weight and torque are a major roll for the survival of this trans. I have many transmissions exceeding those #'s and those guy's were told up front that I will build it, but this is what can happen.And yes 700+ rwhp is a pipe dream and an advertising effort. I would rather not sell a trans then to do something that I know damn well will explode shortly after it is installed. It for me is not just to get the sale. It is about giving you what you deserve and what is right for your application. We are working on some new parts for these units to push that 600rwhp mark. But like anything else it comes with a price. As far as a trade in on the two units, I would recommend you selling the 60 and then purchasing the 80. We do not do upgrade specials on the two different units. Vince
Old Apr 1, 2008 | 10:06 PM
  #24
BlackSSS's Avatar
I beat the **** out of it DAILY However, wasn't really beating it on this failure
Old Apr 11, 2008 | 08:28 AM
  #25
BlackSSS's Avatar
heres the trans table graph requested.
Attached Thumbnails 65e Trans again or something else?-booth_trans_current2008.jpg
Old Apr 11, 2008 | 09:59 AM
  #26
krambo's Avatar
I second the opinion on calling FLT. I produce similar numbers as you in the same platform (AWD SSS) and my FLT LV 65E did just fine. Cutting 1.61 60 ft times in a 5500 pound truck surely challenges the build quality of their work. There is obviously a limit to what the 65 E can effectively handle and alot comes down to daily driving habits, temperature and tune as eluded to in the aforementioned posts. Good luck with whatever route you take.
Texas5.3_1251
Mar 5, 2016 08:10 PM
CammedZ71
11
Sep 9, 2015 02:05 PM
11MPG
Sep 8, 2015 04:52 AM
Mark_k
Sep 7, 2015 10:15 PM
MadDMax66
Sep 5, 2015 01:27 AM
