65e Trans again or something else?
Old Mar 31, 2008 | 10:51 AM
BlackSSS's Avatar
Default 65e Trans again or something else?
I have had this post at two other sites with 0 help or knowledge put forth....I forgot this is the ONLY place where anybody knows anyhting
Anyway:
I just wasted my second BUILT trans in 3 weeks, 4th in a year. I know I could go with an 80 and all that crap, but don't want to....would rather fix the trans one more time, take everyhting off and sell it if I cant get a 65 to work.
I messed around with it today and reverse, 1st and 2nd gears work and Drive will hold for a minute, then pop out????? any ideas? Doesnt sound like total catastrophe as I initieally thought. Something broke as I could hear it snap, grind and evertything else. It sounded and felt liek the driveshaft broke and started dragging, but didn't??? I wonder if maybe the transfer case gave way...???
Thanks In Advance guys
Old Mar 31, 2008 | 11:33 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Wow.....that sucks! Who is building the trans for you or are you doing it yourself?
I would go for the FLT Level 5 myself or throw in the towel and do the 80e. Mine has been holding up to the abuse I throw at it. we have similar hp#'s (without the nitrous I am ~515) and what is your fianl gear ratio?
Old Mar 31, 2008 | 11:51 AM
BlackSSS's Avatar
This is my second local shop around here...ther were suppose to be pretty good at asssembly....I supplied all the "good" parts. I have everything in it that the FLTs have and more probably. 4.10 gears
Old Mar 31, 2008 | 12:07 PM
Breeze's Avatar
11 Second Truck Club
Put an 80e in and be done with it a 60e isnt going to hold up to youre Hp No matter who builds it.
Old Mar 31, 2008 | 04:44 PM
SnakeOiler's Avatar
agreed. I think Vince @ FLT would tell you the same thing.
Old Mar 31, 2008 | 05:00 PM
nonnieselman's Avatar
I agree... i went with the 80E and im not puttin even close to your numbers.. if you break the 80E you have issues.. haha
Old Mar 31, 2008 | 05:48 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Get an 80E it will hold up with your hp level.
Old Mar 31, 2008 | 05:56 PM
BlackSSS's Avatar
I would love to hear that. They sell too many with the same or more power than I am putting out.
Old Mar 31, 2008 | 08:31 PM
BLACK-SS's Avatar
I build gm transmissions and i went through 7 4l60e trannies with every combination of parts known to man before i put a 5 speed in my truck. i dont know how much power your truck is making but i can tell you that when you got on it and you heard that bang like somehthing let go it was the sprag in the input housing that rolled over. i know ive done it twice you chould be able to have it swapped out for a new borg warner one and be just fine.
Old Mar 31, 2008 | 09:08 PM
Mangled03gmc's Avatar
Baltimore Whore
Do you no for a fact that your tranny has more then what flt or other proven companies have in their trannys, not being a dick but a built 65 should hold up to the hp your putting down.I would pull it apart and see exactly what is in there, then try a FLT or Performabuilt tranny out. But if your planiing to make more power then maybe a 80 would be a good swap, since your in a heavier truck... Good Luck
John
