60e cable on 80e bracket?
Old Oct 3, 2008 | 10:48 AM
Superado's Avatar
11 Second Truck Club
Default 60e cable on 80e bracket?
will it work?
do you just adjust the cable?
because last night, I was hooking it up and if the cable is mounted in the bracket, the eye on the end is about an inch past the arm...
thanks!
Old Oct 3, 2008 | 01:31 PM
Superado's Avatar
wow...posted 3 hrs ago and still the most recent post in this forum...
Old Oct 3, 2008 | 01:54 PM
BigKID's Avatar
I used my 60 cable when swaping to the 80 with no problems. Are you sure you put the little bracket that attaches to the gear select shaft on the trans on in the correct orientation?
Old Oct 3, 2008 | 02:18 PM
Superado's Avatar
I just read where you were having adjustment issues when you did your swap...
mine is extended out past the arm...I believe you stated that yours was short of reaching the arm...
the arm and shaft both have flat spots, so you could only have it 180º out...which would put it up top and require pushing thru P-R-N-1-2-3 instead of pulling thru the gears...
so it should be in the correct position I think...
Old Oct 3, 2008 | 02:55 PM
i've got mine on but sometimes it will not go back in park.
Old Oct 3, 2008 | 04:13 PM
CurtD's Avatar
10 Second Truck Club
Al, I think I used the 80e bracket, just took a little adjustment of the black box thing to get it working right. The cable wasn't to long.
Old Oct 3, 2008 | 04:24 PM
Superado's Avatar
thanks!
Old Oct 3, 2008 | 07:23 PM
Superado's Avatar
flipped the tit towards the pan and it fit tight, but it did fit...
got it running...
have P-R-N-D-2...no 1st...
need to adjust the cable...
Old Oct 3, 2008 | 09:53 PM
BigKID's Avatar
My stock cable some how got bound up while the tranny was out. I put a new one in and it worked perfectly. The new one was the original 4L60 part number for my truck.
My fubared cable was doing the exact opposite of what you describe. I would change every gear but would not go back in park.
I think an adjustment would work for you. If you need the procedure let me know and I can pull it off alldata for you. I presume you have the two piece cable?
Old Oct 3, 2008 | 10:31 PM
bigkid hit me up with that alldata procedure mine is doing the exact same thing as yours every gear but want go back in park.
