60E to 80E 4wd Questions
Old Mar 4, 2008 | 04:58 PM
KySilverado's Avatar
Default 60E to 80E 4wd Questions
Guys, I am mulling over the possibility of doing the swap. I know its been discussed a lot and I have read every post on it but I am missing something.
I know I need a 4l80e for a 4wd application. I know I need to swap out the input gear on my transfer case to accept the 80e shaft. What I am not clear on is how do I connect the trans and transfer case together from there. Its an NVG-246 NP8 autotrack transfer case. Do I use the tail shaft housing of the 80e or 60E. Do I need an adapter of some sort with either?
Old Mar 4, 2008 | 05:01 PM
dewmanshu's Avatar
Moderately Differentiated
bolts right up. the conversion adapter (trans to t-case) will be steel instead of aluminum I believe. At least I remember mine being really stout.
Old Mar 4, 2008 | 05:06 PM
So you are saying the 80E 4wd tailshaft housing, conversion adapter in your speak , will bolt right up to my transfer case?
Old Mar 4, 2008 | 05:10 PM
thunder550's Avatar
High on diesel fumes
Yep, there's a skinny metal adapter that goes between the two. IIRC, it's about 3-4 inches wide and just adapts the bolt patterns. If you don't get one with your trans, check a local hard parts dealer. I got mine from TruBest Hard Parts here in Phoenix. I think it was about $35 or so.
Old Mar 4, 2008 | 05:18 PM
So its the 80e.
Then something like this.
Then bolt on the transfer case. Sorry if I'm being dense about this. Having a hard time with it. I guess the output shaft on a 4l80e is much shorter than a 60e.
Old Mar 4, 2008 | 05:19 PM
thunder550's Avatar
Originally Posted by KySilverado
So its the 80e.
That's the one! It also serves as the rear tranny mount too.
Old Mar 4, 2008 | 05:27 PM
Thanks guys. I've got it now.
Old Mar 4, 2008 | 05:41 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Giving up on the ole FLT 60e huh?
Old Mar 4, 2008 | 05:49 PM
Considering it. Doing my homework anyway.
Old Mar 5, 2008 | 06:10 AM
1SlowHoe's Avatar
Destroyer of Transmissions
What is your gear set size? 3.73?
I have 4.10 and am really thinking of stepping up to a 4.56 to offset the long 1st gear ratio in the 80E vs the 60E. Just planting that bug since you will have it all apart anyway.
