4L80E spline question
Old Nov 27, 2012 | 04:14 PM
swift700's Avatar
Default 4L80E spline question
Hey guys, I'm looking at getting a backup tranny and this guy is telling me there were 80E's that had a different output shaft spline count. Can anyone confirm or deny this?
This particular one is a '99 4x4 tranny with the top center bolt hole. Strange.
Old Nov 27, 2012 | 05:22 PM
03sierraslt's Avatar
Thats the first I have heard of that, I know there are different length output shafts but never heard of a different number of splines.
Old Nov 27, 2012 | 06:58 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Drugs will do that to you. 32 spline should be the output on a 4L80E
The only difference is the shaft length between 2WD and 4x4. There are some other minor differences as well.
Old Nov 27, 2012 | 07:18 PM
There are more then two shaft lengths, but I am not sure what the others are for. There is good website that lists all the trans parts but I forget what it is, Vince told me about it.
Edit- Found the site, there are different lengths for different years I guess. I am actually seeing 6 different lengths. wit trans .com
Old Nov 27, 2012 | 07:33 PM
1FastBrick's Avatar
All depends on what it was installed in. Slip yoke vs Bolt on yoke, 4x4, the mechanical brake drum on the 1 ton box vans and so on down the line.... LOL
Old Nov 27, 2012 | 07:49 PM
Vince B's Avatar
The difference in the lengths is for a trans parking brake assembly. All regular 2wd length and 4wd shaft lengths are the same. Also all have the same spline count.
Old Nov 27, 2012 | 07:54 PM
1FastBrick's Avatar
So 2WD and 4x4 are different lengths but your saying all 2WD has the same length and all 4x4 are the same length???
I was under the impression there was a slight variation in slip on yoke Vs. bolt on yoke length.
Old Nov 27, 2012 | 09:13 PM
swift700's Avatar
Thanks for the replies, guys. I kinda figured he was out to lunch. Will go pick it up tomorrow. I'm going to rebuild this one myself. I have the shift kit already but can anyone recommend a good rebuild kit with Kolene steels?
Old Nov 28, 2012 | 06:01 AM
Vince B's Avatar
Yes that is correct. The changes start when GM bolted the parking brake.
Old Nov 28, 2012 | 06:15 AM
Interesting.
GXPJAY
Feb 13, 2022 08:15 AM
Blue03sss
Mar 7, 2019 05:06 PM
USMCvet0311
Aug 1, 2015 07:45 AM
alex226
Jul 16, 2015 10:55 AM
bsn1989
Jul 16, 2015 08:20 AM
