4L80 swap keep PWM or delete PWM now that is the question???
Resident Retard
Well i am going to be swapping my 80 in next week and I am wondering if you guys are deleting the PWM with the tune (setting min/max to both 100%) or deleting it via wiring harness.
I haven't done the swap yet, but I was told "For performance I would delete PWM. Pulse width modulation makes the converter lockup softer but puts more wear on the clutches.". So I would delete PWM.
Depends on which converter you are getting. I recommend leaving it enable for our multi disk. Give you a little softer lock up at light throttle. With the on/off style the lock can be a little abrupt on a multi. If you are going single, then I would delete the PWM.
Chris
Chris
Resident Retard
Chris
Chris
Nimoryan
Jul 5, 2015 03:50 PM
