4l60e build with $100 core...
Old Feb 23, 2016 | 04:42 PM
  #311
Wolftrk99's Avatar
Id love to use the welding idea, have a slight disadvantage in that i have no welder..
Old Feb 23, 2016 | 04:43 PM
  #312
1FastBrick's Avatar
Custm2500's Rude Friend
That might be an issue...
Old Feb 23, 2016 | 05:20 PM
  #313
tgui's Avatar
Gezz, I don't log in for 1 day and the shenanigans begin...
I like to use the welding Idea too, Only issue is the engine is open and exposed. The welding slag from the arc will bead up and run down into the engine.
If you have to do it, wrap everything including the valve stem with a clean leather welding blanket. The use a nut and weld through the center of it...
I do the same for exhaust bolts. It's the best way to extract them.
Good luck!
Does this way work with flux core welders?
$99 HF
Old Feb 23, 2016 | 05:22 PM
  #314
1FastBrick's Avatar
$99 HF
It might work. I have never used a flux set up before.
Old Feb 23, 2016 | 06:32 PM
  #315
Wolftrk99's Avatar
It would work just makes more mess!!!!
Btw got the pos out!!! HALLEFUCKINGLUJAH!!!!!!!
Old Feb 23, 2016 | 08:49 PM
  #316
tgui's Avatar
Woohoo!!!!
Old Feb 23, 2016 | 08:53 PM
  #317
Wolftrk99's Avatar
Bank 2 done!!! Remind me next time to just pull the damn heads.... You better believe the 6.0 im building for the yukon will have the springs swapped on the bench before they go on the engine!!!! Hell if i was smart this would have been a swap springs onto the ither heads and swap heads..... Probably would have been quicker and less taxing mentally!!!
Old Feb 23, 2016 | 08:59 PM
  #318
1FastBrick's Avatar
How about use the proper tool next time...
Old Feb 23, 2016 | 09:08 PM
  #319
Wolftrk99's Avatar
Define proper tool!!! Stock springs the crank style compressor is awesome..... Anything beyond that they are a pain or theres something im missing.... And proper tool is the bigc clamp looking compressor
Old Feb 23, 2016 | 09:14 PM
  #320
1FastBrick's Avatar
lookup Proform 67605 for LS heads still on vehicle.
It's the same one comp, crane, and every other one like it sells.
It's not cheap but lets you do 2 at a time...
