40K Tru-Cool TFT data
Old Aug 12, 2010 | 02:01 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Default 40K Tru-Cool TFT data
Hey guys, we all know that the 40K Tru-cool works. So this post is kind of redundant I guess. But I was just looking thru a bunch of my log files and figured I'd post up just exactly how much it lowered my TFT's.
With the stock (baby) aux transmission cooler, my TFT's were typically 149* at the starting line, and 151* at the finish line. Not too bad, certainly more efficient that I expected, and not high enough to cause damage.
After replacing the stock aux cooler with the 40k, my TFT's are typically 135* at the starting line, and 138* at the finish line.
Old Aug 12, 2010 | 04:07 PM
Gordy M's Avatar
Here is another example of the 40,000 Tru-Cool. Hauling a 7700lb trailer with a 6000lb SUV with GM cooler, my trans temps ran 205 to 215 when cruising down the Xway at 70mph. After the Tru-Cool install the trans temps dropped to 155-165 deg.
Old Aug 12, 2010 | 04:49 PM
CharlyNali6.2's Avatar
nice are al tru cools the same or is there diference like where would i look for one for my 07 6.2?? i tow my boat and my temps go as high as 195 some times..i guees its not all to bad but the cooler the better i guess
Old Aug 12, 2010 | 08:15 PM
terravast4's Avatar
all the same unless you live in colder climates then has some sort of bypass valve.
Old Aug 13, 2010 | 08:12 AM
Gordy M's Avatar
If you have the small trans cooler from GM just replace the cooler with the Tru-Cool 40,000. Do a search, for DIY all the info is there, for those in a hurry, on of our forum members has an excellent install kit with everything you need. Bypass is not needed then for northern climates for winter.
Old Aug 13, 2010 | 08:33 AM
LS1FREEK's Avatar
13 Second Truck Club
Thats interesting. I need one too. I have the factory external one thats like 6x8 inches? Do the factory lines clip right onto the tru cool coolers?
Old Aug 14, 2010 | 07:59 AM
Gordy M's Avatar
No they do not, you have to turn one of the lines 180 deg (cut the line and add a splice/rotate the line. The other line you have to get out of the brace and move it over to the other fitting. If you buy the kits, they are included as well as the fixtures to mount the cooler in the stock location and a place for the outside air temp gauge.
blowngmc
32
Oct 12, 2017 11:59 AM
zblee
Nov 11, 2015 12:41 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
murderedSS
Sep 27, 2015 10:16 PM
dantheman1540
Sep 15, 2015 08:28 PM
