2005 Chevy Crew Cab.. What axle ?
Old Jul 24, 2007 | 01:08 AM
Tydriver's Avatar
Default 2005 Chevy Crew Cab.. What axle ?
Best guess is a 10 bolt 8.5" but I am not sure.. Anyone know for sure what was offered in the crew cabs ?
It does have drum brakes (boooo.. my '02 had discs).. But I wanted to know for sure what rear end it has..
Thanks !
Todd
Old Jul 24, 2007 | 04:25 PM
nightrunner's Avatar
Mr. Obvious
its a 10-bolt 8.625" unless you have a VMAX then its a 9.5" 14bolt
05 was the start for rear drum brakes
Old Jul 24, 2007 | 05:00 PM
Tydriver's Avatar
Well that sucks!! I was hoping to score this off ebay for it..
http://cgi.ebay.com/ebaymotors/Detro...54846549QQrdZ1
Glad I asked, thanks for the reply..
Old Jul 24, 2007 | 05:06 PM
Mr. Obvious
im not sure on that locker thingy on ebay ( never heard of that before) but 8.5" gears will work just different bearings or something, not sure. it cant be much of a locker for only $25. get either a detroit trutrac or a eaton lsd for a good lsd.
someone who knows what the difference between the 8.5" diff. and the 8.6" diff. PLEASE chime in.
Old Jul 24, 2007 | 05:33 PM
Tydriver's Avatar
Lockers are basically a LSD diff on steroids.. TracTech is the ones to talk to for good locker parts. They are the equivalent of a Detroit locker only a slightly different design. (you replace the spider gears with these parts and re-use your existing diff case whereas the true Detroit Locker replaces the case as well). Doing this keeps you from having to re-setup the entire rear end tolerances again.
The $25 is an awesome deal on this part, last time I checked, it was close to $450-500 for this part NEW.
The application guide specifically mentions that it WONT work with the 8.625 ring gear, I was hoping I had the 8.5" rear. I am not up on all the new(er) axle options so I didnt bid on it.. The only "bad" thing I can say is that a locker on the street can be a bit of a hassle if you are not expecting it but I can live with it for the added performance both rear wheels spinning instead of one.
Old Jul 24, 2007 | 06:07 PM
Mr. Obvious
i know about lockers but that didnt look like genuine detroit stuff but if know what the product is its all good.
no reason for a locker unless its a pure offroad rig. the detroit TT will lock both up just fine and unlock them when needed
Old Jul 24, 2007 | 06:48 PM
Tydriver's Avatar
Yeah, I guess I am just a little hard on the throttle in my truck, the one wheel peel gets old when its raining or even mild throttle pressure around a corner in my truck. I don't even have a Gov-Lock Garbage Posi in it, its literally wide open rear end so I figured if I could score a bargain like that I can live with it and KNOW that I have true traction in the back. Last weekend I went down to a friends house and we took his boat out, if I hadn't had the auto-trac in Auto mode it would've been a smoke show getting the boat out of the water.
Old Jul 24, 2007 | 11:21 PM
5-speedSierra's Avatar
the tru trac is awesome. ive got about 4000 miles on my toyo proxes and theyre bald. and i had yet to look in the mirror and see a one wheel peel.
i wouldnt worry about traction problems with it
flatblack83
Jan 3, 2026 07:10 PM
FlyingLow
Nov 24, 2015 10:05 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
zraffz
Sep 8, 2015 07:40 PM
