Returnless Bucket Build
Old Dec 24, 2014 | 01:30 PM
  #21
Tilt's Avatar
Well, after getting the pump out, the suction end is a little different than yours and the Walbro. This may still work, we'll see.
Old Jan 24, 2015 | 08:09 AM
  #22
03sierraslt's Avatar
Don't cut the bed..... Unbolt the bed or drop the tank, either is easy enough. You should be able to get a walbro 255 to work just fine in your bucket. If you are getting a Walbro pump then get it somewhere repuable as there are cheap knock offs and having a fuel pump fail sucks.
Old Jan 24, 2015 | 09:59 AM
  #23
Atomic's Avatar
I have a gauge for that
Dont even bother with a 255, get a 400 at least.
Old Jan 24, 2015 | 10:07 AM
  #24
Last 400 I seen on a Returnless setup ( ok regulator in tank) caused over pressure at idle as the regulator couldn't dump enough.
Old Jan 24, 2015 | 04:29 PM
  #25
Atomic's Avatar
Its not a big deal
Old Jan 24, 2015 | 04:48 PM
  #26
DRAENOR's Avatar
Banned
It does. I run ~64psi at idle and run ~58psi at WOT. Idle tuning is a bit tricky, but not hard.
Old Jan 24, 2015 | 04:56 PM
  #27
I would be willing to bet you are not running much boost either. Turn up the boost and watch the fuel pressure drop.
Old Jan 24, 2015 | 05:12 PM
  #28
DRAENOR's Avatar
Banned
Not yet, just 6psi. Im about to pulley down and see and have a return-style upgrade planned, if it comes to it.
At my current set up, it suffices.
Old Jan 24, 2015 | 06:23 PM
  #29
I pushed mine a decent amount, but I was running twin 255's second was boost activated and allot of meth. If anyone needs pictures of 04' style bucket let me know, I have three apart on my workbench. I am building my return setup now.
Choda
Jun 5, 2025 06:43 PM
OHsixLS3
Sep 25, 2015 11:20 AM
2500ZL1
Sep 12, 2015 03:50 PM
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
