Returnless Bucket Build
Finished product looks good!
Larger fuel pumps have the capacity to empty the bucket much faster than a stock bucket. Since large pumps are usually used with higher power engines with a greater fuel requirement, most people dont size their pumps correctly and so they drop fuel pressure. What that really means is no fuel is being returned to the tank so the bucket empties even faster. Obviously the fuel also sloshes to back on hard accel so the bucket doesnt get refilled from fuel in the tank beside it through the bottom.
His setup is exactly stock. I doubt he will ever have a problem starving the pump because his fuel requirements are low, and pump is small.
Thanks Richard! So is this why some of the Walbro Modules have "jet pumps"? To better keep the fuel in the bucket?
Does a 400 fit the bucket as well as the 255? I'd like to keep the bucket pretty close to stock as well.
Thanks for the comments and i hope this does help someone on a bucket build....Now i know what is involved and can really be dangerous now lol!
I would suggest not using worm gear clamps, they make crimp clamps that won't work loose and clamp more securely. Racetronix sells them and you can actually get them at your local Home Depot in the plumbing section.
Returnless is really not a good name for it.
All fuel systems are return style. The only difference is "return" setups have the regulator near the fuel rail, so you see 2 lines to the tank. "Returnless" setups have the regulator in the tank, so you only see 1 line. The only difference is where the regulator is in the system.
If you can give a manifold reference to a tank regulator it will have the advantages of both styles.
Enjoy, and let us see the results! Pix go a long way to help everyone in the same boat!
Thanks for the write up. I am needing to do the same thing for an 04 Escalade to get it running before pulling the motor for a swap. Good news is I can use the same pump after the swap to go in the 87 sening unit. Have you had any problems since doing this?
