New inline fuel system
Old May 9, 2012 | 10:45 PM
Superado's Avatar
11 Second Truck Club
Default New inline fuel system
** Pics and parts list **
When the truck was running its best on the old set-up I started fighting fueling issues w/ the Walbro in-tank feeding the Bosch 044 inline. I didn't want to go thru that again this go around, sooooo...
here's the new fuel system that I came up with and had installed today:
Dual (-10) x 1/2"NPT from the rear of the stock tank to (-10) 90 degree Push-lite fittings:
Routed the two 5/8" hoses along the metal fuel tank shield:
Hoses routed under and over the cross-rail:
Dual (-10) 100 micron filters into dual Bosch 044 inline pumps...out w/ (-8):
Dual 1/2" hoses into (-8 x -8 x -8) "Y"...out w/ (-8) x (-6) reducer...3/8" hose to fuel rail:
Old May 10, 2012 | 08:15 PM
SCREAMINXL's Avatar
Looks awesome! In for results.
Old May 10, 2012 | 08:19 PM
MGMC's Avatar
12 Second Club
if everything works properly, this should be a sticky for refrence.
Old May 10, 2012 | 09:00 PM
milkey57's Avatar
I like that setup good job let us know how it works!!
Old May 10, 2012 | 09:26 PM
quicksilverado's Avatar
Do both pumps run all the time Al?
Old May 10, 2012 | 09:33 PM
mitchellmade's Avatar
MASS seller approved
just curious if you checked pressure consistency in after the the -8 lines into -6 line before installed on your truck ? do you think the two into one would be turbulent and cause a "foaming" effect? what about a drive shaft loop? to protect those lines
Old May 10, 2012 | 09:38 PM
AndysC3's Avatar
Are you going to use any type of fuel pressure regulator?
Old May 10, 2012 | 10:08 PM
Superado's Avatar
Originally Posted by MGMC
if everything works properly, this should be a sticky for reference.
Thanks guys!
Yeah, Dave...I decided to run them both full time.
No, I didn't check pressure consistency from -8 to -6.
All dual pump systems have to y together at some point...not sure if the reduction from -8 to -6 will cause anything except increased pressure.
I have a "non-loop" near the front of the front DS...something to "pass" tech at the track w/ slicks. After seeing the beating that the tank shield took when I dropped the DS a couple of years ago, I will definitely be installing a full loop front and rear soon. The rear, short DS dropped from the pinion when two straps came off. That shaft beat the $#!+ out of the tank.
Stock 1:1 FPR
Old May 10, 2012 | 10:22 PM
05_quick4door's Avatar
Do you anticipate any starvation if you are slowing down or park at a funny angle? Or is this one of those "never go below x amount of fuel before you fill up"?
Old May 10, 2012 | 10:53 PM
Superado's Avatar
I do...to a certain extent...and yes it is "one of those"...in my mind anyway.
I had starvation issues from the location of the stock pump when racing.
The truck has been my DD for 11 years and 285k miles...until a couple of months ago at least...when I purchased a new (to me) DD...so no biggie...til it happens.
