FPR routing
#21
I have a gauge for that
With higher pressure the pump has to work harder as Pat pointed out, and some injectors dont like to operate at higher pressures. Lot of the crazy high boost 4cyl guys have to run low base pressures so the injectors still operate at high boost.
Look at my stickied thread in the fuel injector section if you want more info on injector flow vs pump flow. Its all a balancing act.
Methanol injection is its own separate beast, more or less done independent of the main fuel system. Main fuel base pressure has no effect on meth injection.
#26
Bringing up old thread.
When I dropped my truck off at Nelson's to get the new engine installed, he mentioned that they do no use boost reference in any of their power adder builds. They set to static 60psi and tune accordingly... The truck is setup for boost reference, but they will be providing the tune once all work is done. I have HPT for once i get the truck back, but I am curious how this will work.
I get the injectors will be scaled differently to compensate, but I only have 60# Deka and a DW350iL pump. Wondering how this will pan out.
GeorgeC
03-07-2005 07:18 PM
