FPR routing
FPR routing
This is how my FPR is plumbed.
Feed coming in.
Front of rails connected.
Exit into FPR inlet. Other inlet plugged. Return line to tank.
I know this is not the best way to do it but wondering if the way I have it set up will cause any issues? This was just the easiest and cleanest looking. Thanks for your input.
Feed coming in.
I have a gauge for that
That will work fine.
Boost reference means connect your regulator to the lower manifold so it sees boost/vacuum. You definitely want to do this as it keeps injector size constant with vacuum and boost. That silver hose fitting pointing down, connect that to the manifold after the throttle body and update your tuner on what all youve change
I am running a surge tank fed by stock pump to 2 450 e85 pumps. My plan was to pull out the stock FPR (now I'm not sure it has one might be FPCM controlled) but not sure what I removed. I will wire 1st 450 into factory pump signal (using hotwire kit) so it runs with factory pump and 2nd pump to a hobbs switch. Do I need to disable the FPCM similar to this?
https://www.performancetrucks.net/fo...-power-547334/
or do I leave that alone so tuner can just set factory pump to run all out all the time?
This is the thing I thought might be a fuel pressure regulator. I removed it along with stock fuel filter. Last couple of pics
https://www.performancetrucks.net/fo...-549168/page6/
I assume running boos reference does not change how the pumps are wired?
With boost, it is very important and beneficial to reference it, or you will have to massively oversize your injectors.
