Routing power cable through firewall
Alright, I'm new to the whole late model GM truck scene...
Anyway, the F-body cars have a nice built-in secret hole underneath the PCM which makes it very easy to route wires, cables, etc. into the cabin of the car from the engine compartment.
I'm about to start installing some audio equipment left over from other cars into my '04 Silverado, and I want to know if there's any existing place large enough for a 4ga. power cable to go through the firewall. I don't want to drill a new hole if I don't need to.
Thanks guys!
Thanks guys!
I AM A MOTHERF*CKER
On the fire wall, between the master cylinder and the fender, you'll see a black rubber gromet about 2-2.5" across. That goes straight in to the cab -- there is a wiring harness coming through the existing center hole, so I just cut an additional hole in the grommet and passed through there.
It's a strange gromet -- it has an inner donut of hard rubber and a soft rubber boot. The boot is what needs surgery.
Originally Posted by GeorgeC
Cool. That will make things easier.
Man don't do it there! I might just have bad luck or be a plain old dumb ***, but I was installing my guages for the piller mount yesterday. I cut a clean x in the exact gromet to feed all of the wires through, the problem started when I tried to cut the x on the other side of the gromet through the first cut. When I appled pressure to the knife the windsheild wipers jumped, alarmed at this point I jumped in the cab to verify that nothing was on only to see a small amount of smoke coming from the stereo/ac control area. I turned the ignition on everthing seemed to work but the displays on both. After a few minutes at looking at fuses I started the truck again everthing seemed to be working. This morning on the way to work I noticed that the ac compressor will not engauge or start. I stuck my finger in the x I cut to try and feel any wires that might be damaged, everthing feels ok. If any of you guys have any idea what I messed up or how to fix it please help. Sorry for highjacking this thread I'm just too embarrased to post my own.
i did the same thing. i had it like that for over 5 years now without of problem. i wrapped eletrical tape around the 4 gauge wire to prevent wear and tear
ARC
57
02-21-2022 10:54 AM
TimDave217
08-24-2015 04:38 PM
