FPR routing
Old 02-14-2018, 12:16 AM
crashmymax's Avatar
alternatively, some with a good fuel system/injectors will run static 58-65 psi for a KISS method.
I'm undecided, which is why I'm asking/paying devils advocate...I hope it sparks some conversation that could help us both decide
This is what I had planned to do. I thought having a set constant fuel pressure was the way to do it. Going with what my tuner says and will be using boost referencing.
Old 02-14-2018, 03:57 AM
03sierraslt's Avatar
Originally Posted by Atomic
There is zero advantage to that. The only reason to run an unreferenced regulator is if it is far away and would not be pratical to tie it in. This is the case with "returnless" systems. The name is a misnomer as there is a return, it is just inside the tank so you dont see it.
With boost, it is very important and beneficial to reference it, or you will have to massively oversize your injectors.
Agreed. Vac/boost ref is actually the easy/simple way, if you have no ref then you have to scale your injector tables like a returnless system.
Old 02-14-2018, 02:47 PM
TXsilverado's Avatar
so with boost referenced, where do you set the fuel pressure at idle?
Old 02-14-2018, 03:10 PM
kbracing96's Avatar
Disconnect the ref and set fp to 58psi, then reconnect the ref. That way your fp is always set static to 58psi and vac/boost adjust it accordingly.
Old 02-14-2018, 03:11 PM
I have a gauge for that
Atomic's Avatar
Wherever you want. Factory LS setting is (4bar) 58psi. If you run a **** ton of boost or huge injectors you may set base pressure at something less, 3bar (42psi) is common.
Old 02-14-2018, 04:35 PM
Mines at 48. As long as your injector tables are tuned to match then do as you please. There is a happy medium depending on the fuel system and boost level.
With 58 base I didn’t want my pressure at wide open being mid 70’s so I lowered it.
Old 02-14-2018, 06:22 PM
MikeGyver's Avatar
......With 58 base I didn’t want my pressure at wide open being mid 70’s.....
Why not?
Old 02-14-2018, 07:37 PM
Originally Posted by MikeGyver
Why not?
Pump output decreases and amp draw increases. On gas my injectors are plenty big enough. In process of adding another pump for E85 so I’ll turn pressure back up then.
Old 02-14-2018, 11:08 PM
does any of these methods change with a large dose of methanol injection in boost? as in static 58 psi with 30+ gph
carburetors are so up my alley. set it and run it without all the drama LOL.
Old 02-15-2018, 07:10 AM
No. Not as long as the meth is stand alone. They are two separate systems
Quick Reply: FPR routing
