Am I crazy to try this?
Old Aug 19, 2015 | 11:04 PM
Sevex's Avatar
Snail Fab
Default Am I crazy to try this?
So I am in the process of collecting parts to finish my fuel system in my 2000 Silverado with a turbo 5.3
I am hoping to make around 750-800hp all said and done and want to make sure I will have enough fuel as I don't want to run into issues.
I just purchased an 05 tank and bucket for cheap so I can fit dual 450's without hacking the bucket. But now my question is if stock lines and filter will be capable of supporting dual 450s at 800hp or if I should I just plan on running a -8 line to the front and use stock feed as a return? If using stock feed as a return what are you guys doing about the stock fuel filter?
Right now my fuel system is as follows:
05 tank and bucket
Dual 450's
Edelbrock proflo rails fed into the back of one with a -8an crossover
Aeromotive 13129 reg.
Also since this reg only uses -6 fittings should I just run -6 out of the rail to the reg? Or should I uses -8 from pump to rails to reg with just the -6 return?
Thanks
Old Aug 20, 2015 | 12:58 AM
lsxperformance's Avatar
850 crank or wheel hp? I've done -6 line 1000hp on e85. If you running corn you have to run a flex fuel filter and ya you can use factory feed as a feed or a return. Whatever works I'd try to make your feed and return same size tho so the regulator can do its job more effectively. When your just cruising around.. Hope that helps
Old Aug 20, 2015 | 10:38 AM
GOOCHMAN's Avatar
i am single 450 -8/-6 return billet 100mic filter 60lb injectors a1000 reg 91 and meth well in your power range turned up 43lbs base 1:1
I was on single 450 in tank 6lbs stock line and filter returnless nnbs rail
it was hard to tune because my pressure was high and not 1:1 with boost but my fuel was there never got out of the 11.2 11.4 range wot
so I would run your setup like mine it was easy ran a -8 fitting from stock outlet -8 to reg -8 to rail returned out of the bottom of the reg -6 to the top of the tank drilled a hole and ran a billet fuel bulk head I have no leaks and no fuel starve issue what so ever
are you wanting to run e85 is the only reason I see to need 2 450's I am on 91 in the Midwest with 60's and meth and my injectors are at like 40%dtyc
Old Aug 21, 2015 | 11:16 PM
Sevex's Avatar
Snail Fab
It will be on pump 91 and water/meth as we cannot get e85 anywhere around here
I would like to do 800whp
I just want to make sure that I have enough fuel, I have heard that a single 450 will support 750 on gas with no issues, I just wanted to be positive that I never run out of fuel.
Injectors are Siemens Deka 80's
Old Aug 21, 2015 | 11:24 PM
GMCtrk's Avatar
Let's just put it like this...if you think you're the first to do something, you're probably not.
Old Aug 21, 2015 | 11:43 PM
Sevex's Avatar
Snail Fab
I think I remember you trying to run dual 450's on stock lines? How did it work?
Old Aug 21, 2015 | 11:56 PM
GMCtrk's Avatar
the stock feed line and filter are fine.
The stock return line is a restriction.
I've already priced out all the fittings and line for -8 return from my Aeromotive regulator back to the tank and it's going to be around $200.
Old Aug 22, 2015 | 12:10 AM
Sevex's Avatar
Snail Fab
Ok well I guess I had better just do a -8 feed and use stock feed as a return , then there is no question
Old Aug 22, 2015 | 12:12 AM
GMCtrk's Avatar
I would recommend -8 feed and return. sto
walledition
Feb 24, 2026 03:27 PM
trxmxzx
Sep 23, 2015 09:15 PM
Goat's ss
Sep 22, 2015 01:07 PM
Lthompson
Sep 15, 2015 07:55 PM
726.0chevelle
Sep 12, 2015 09:24 AM
