wtb procharger f1 ??
Old Sep 5, 2008 | 09:42 PM
  #31
Regency04's Avatar
I know you guys were talking about cog belt setups and i found this one off a corvette that i'm going to try probably
Old Sep 5, 2008 | 10:48 PM
  #32
2toneblown's Avatar
Cherry, good luck with the procharger. I already tried a F1-R on my 408 and had custom brackets made due to the stock brackets flexing and allowing the belt to walk off the ribs. I also had a manual tensioner so that I could really tighten down on the belt. I spent probably $2000 on belts in about 6 months. I would chunk belts in burn outs, @ the 60' and anywhere down the track and only got about 3 or 4 full passes out of it. I dont think that the 8 rib would do much different, Cog I believe would help. I would say go turbo or twin turbo. I think I am going to make a twin kit for the escalade over the winter. I still have the custom brackets I made for the procharger if your interested, here is a ferw pics i can find of the bracket
Old Sep 6, 2008 | 07:46 AM
  #33
phasemaster1's Avatar
2toneblown how much thicker did you have to go o0n the new bracket? Also what is that sensor just before entering the TB?
Old Sep 6, 2008 | 08:41 AM
  #34
Superado's Avatar
11 Second Truck Club
should be IAT
Old Sep 6, 2008 | 08:58 AM
  #35
jasond26's Avatar
I bet the reason it was throwing belts was because you had a manual tensioner. For a supercharged application you need a spring style tensioner. As you get higher into the rpms the belt begins to stretch and you need a tension that will take up the slack when this happens. I have the 8rib an was having bad belt throwing problems from the begining. I ended up getting a gates belt tensioner and larger idler pulleys to take up the slack with the belt. I have not had any more problems. I have made many wide open blasts and short burst hits and no belt issues and no slipping.
On another note, that bracket you had made was awesome. I think the easiest way to go cogs would be to change over to vette accesories and get the ATI perfromance cog system or to have a new bracket made to push the blower forward and run a cog off the front of the balancer, which is what I think I am going to do in the future whan I go to the F2
Old Sep 6, 2008 | 10:39 AM
  #36
2toneblown's Avatar
i tried it with all different tension on the belt
madmann26
Apr 29, 2020 09:17 AM
murderedSS
Sep 27, 2015 10:16 PM
MOBBN
Sep 22, 2015 08:07 PM
murderedSS
Sep 22, 2015 03:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
