wastgate size?
Old Mar 7, 2014 | 07:22 PM
stroker87's Avatar
Default wastegate size?
trying to find out what size wastegate I should use?
lq4 stock bottom
317 cnc's
triple 12 cam
60# inj.
plain on 10 to 12# of boost what size should i run? 35mm 40mm 50mm or?
i can get a killer deal on a tial 35mm but dont know if its to small?
Old Mar 7, 2014 | 07:35 PM
timmay208's Avatar
what size of turbo?
Old Mar 7, 2014 | 07:41 PM
Atomic's Avatar
I have a gauge for that
Whos kit?
Off hand I would say 50mm. Better to have too much gate than too little.
Old Mar 7, 2014 | 07:43 PM
timmay208's Avatar
anything larger than a 62mm i would say at least a 45mm. im doing a tial 45 on mysetup with a s472
Old Mar 7, 2014 | 07:47 PM
stroker87's Avatar
I'm new to this so i'm not sure I got the lingo down so bear with me
its a 73mm turbo the hot side has .96 a/r on it, I'm sure its a off brand turbo there is no name or model stamped into it I dont know any thing more about it
its a home grown kit that came with my truck when i bought it, its a rear mount setup (yeah I know) i want to get it installed and see what it does i'm really just hoping to make 500 to 600rwhp
Old Mar 7, 2014 | 11:10 PM
WICKEDOWESIX's Avatar
Get a 50mm gate. The turbo smart pro gate 50 is nice.
Old Mar 8, 2014 | 12:52 AM
timmay208's Avatar
whatever you do dont do a 35mm, its more likely to have boost creep at lower boost levels,
Old Mar 8, 2014 | 12:54 AM
stroker87's Avatar
can you explain that?
Old Mar 8, 2014 | 01:00 AM
timmay208's Avatar
larger turbos will i guess you say over power the wastegate, as in the wastegate cant let enough out to keep the turbo on a steady low boost level.
if you planned on doing boost that was higher and closer to the peak of efficiency range then id say a smaller gate would be ok
Old Mar 8, 2014 | 01:21 AM
stroker87's Avatar
thanks for explaining that I follow what your saying
dsbodley
Nov 14, 2015 09:46 PM
GMCtrk
Oct 5, 2015 11:18 AM
old motorhead
Sep 29, 2015 08:22 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
