wastegate question?
Old Oct 29, 2008 | 07:45 PM
xxwackerxx's Avatar
Default wastegate question?
when the truck was idling i was hearing this funny tinging kind of sound. so i started to cover up the wastegate dump and it was sucking air in? is it suppose to do that? and when i covered it ( not completly ) the sound went away so i figured it was caused from the air being drawn in... sorry this was baffling me all day...
Old Oct 29, 2008 | 07:51 PM
shawnss's Avatar
my wastegate has never done that. im pretty sure its not suppose to it almost sounds like it got stuck open. what brand is it. i could be wrong but i never heard of that.
Old Oct 29, 2008 | 07:53 PM
xxwackerxx's Avatar
its sts...what do i do if its stuck open, play with it or get a new one?
Old Oct 29, 2008 | 07:58 PM
shawnss's Avatar
are you talking about the exhaust dump part of the wastegate that is sucking in air or the little tube on the side ive never seen the sts one. i run a tial.
Old Oct 29, 2008 | 08:06 PM
xxwackerxx's Avatar
the dump...i dont know all i know is its an sts kit i bought used. the hose part has a hose on it for the boost controller but the boost controller isnt wired in yet
Old Oct 29, 2008 | 08:08 PM
alanderson1978's Avatar
IIRC, the STS comes with a Tial.
The WG should be shut at idle, so you shouldn't feel anything coming in or out.
Old Oct 29, 2008 | 08:09 PM
xxwackerxx's Avatar
hmm so whats my next step?
Old Oct 29, 2008 | 08:12 PM
S/C Z71's Avatar
Banned
Get a new one.
kbracing96's Avatar
Pretty sure he's talking about the blow off valve. Sound like you have it on a stock motor and has more vacuum then the other setup. You probable need a stiffer spring in it or adjusted (tightened) if it's adjustable
Old Oct 29, 2008 | 08:15 PM
xxwackerxx's Avatar
ive had the kit a week!...how come im not losing boost or anything...im still hittin 5psi?
