wastegate question?
Old Oct 29, 2008 | 08:15 PM
shawnss's Avatar
you could also take it off and take it part maybe a piece of carbon build up broke off and could of made it stick open. maybe sand the exhaust build up off and try reinstalling it and see if the helps. new wastegates are about 300 or so
Old Oct 29, 2008 | 08:18 PM
xxwackerxx's Avatar
you mean i need to put like a 8pound spring in there? sorry im still green when it comes to this schit
Old Oct 29, 2008 | 08:20 PM
xxwackerxx's Avatar
yeah i def about fixin this crap SrA dont get paid to much haha
Old Oct 29, 2008 | 08:26 PM
kbracing96's Avatar
Are you talking about the waste gate at the back of the truck by the turbo, or the Blow off valve under the hood, buy the throttle body???
Old Oct 29, 2008 | 08:30 PM
shawnss's Avatar
well no matter what at idle your wastegate should not be open. if it is blowing or sucking air then there is something not right. wastegates should only come open when you let off the throttle and the should dump the exhaust pressure. its cool that your new to the turbo world you have to start at some point. I bought my truck two year ago with a turbo kit already installed and i didnt no the first thing about boost but i know now.
Old Oct 29, 2008 | 08:31 PM
speedaddict's Avatar
yea...if you have a digital, take a pic of where its sucking in air
Old Oct 29, 2008 | 08:38 PM
shawnss's Avatar
Originally Posted by xxwackerxx
ive had the kit a week!...how come im not losing boost or anything...im still hittin 5psi?
you should still be hitting boost. the only way you woulndnt hit boost is if your blow off valve is staying open. if the waste gate is open you would just need more RPMS to hit full boost.
Old Oct 29, 2008 | 08:41 PM
xxwackerxx's Avatar
the waste gate at the back of the truck...yeah i installed it all last week everynight after work....i got a killer deal so i couldnt pass it up
Old Oct 29, 2008 | 08:43 PM
xxwackerxx's Avatar
i just went out and started it and i looked at it, it looks closed but its suckin and blowin pretty bad
Old Oct 29, 2008 | 08:49 PM
alanderson1978's Avatar
Try pulling it off and getting a closer look.
If you have a helper, see if it does it at higher RPM. What RPM is your idle at?
