Wanting to go with boost. Need Help.
Old Jun 10, 2010 | 10:36 AM
kwk174's Avatar
Default Wanting to go with boost. Need Help.
So after saving for a while im looking into going FI. Ive got a 370 with stock bottom end, milled heads, and .030" gaskets. Im running 11.3:1 and was wondering would i need to get thicker gaskets to safely run boost. or can i run less boost? Any help needed.
thanks.
Old Jun 10, 2010 | 10:56 AM
lownslo's Avatar
your best bet would be to go with nitrous if you are running that high of compression. 10:5 is a good boost compression. Explain what you mean about a 370 with stock bottom end. I don't have enough info on that set up to tell you how much boost you can run.
Right now with what i know i would say get a really good tune and you could get away with 8-10psi but that compression is high to up the boost much more than that with out some great internals.
Old Jun 10, 2010 | 01:21 PM
kwk174's Avatar
its a 6.0l/370 with 4.030 replacement pistons(not forged), original crank and stock rods. So was wondering if running a blower would be safe. and if so how much boost?
Old Jun 11, 2010 | 02:09 AM
Blown06's Avatar
8 Second Truck Club
I'm thinking 6-8 psi would be safe on a perfect tune. More than that and your asking for trouble.
Old Jun 11, 2010 | 08:17 AM
lownslo's Avatar
stock crank and rods.....yea with that compression, def wanna stay 5psi if ya want any timing. I wouldn't push past 7psi on that set up unless ya wanna take out the old stuff and put in some new stuff.......
One question, why build a 370 and put stock rods and crank back in?
Old Jun 11, 2010 | 08:27 AM
Rick_Vor's Avatar
Swap out the geads for some unmolested 317's and boost it all you want. If your really at 11.3:1, even with just 8lbs your tune needs to be spot on + you should add Meth for the octane.
If your serious about going FI, swap the heads. You can sell your milled heads and the compression drop will only cost you some MLS head gaskets.
Rick
Old Jun 11, 2010 | 10:14 AM
kwk174's Avatar
Thanks for all the help.
The reason for using stock crank and rods is due to my budget at the time. Now wishing that could have done forged.
Old Jun 11, 2010 | 10:47 AM
lownslo's Avatar
i know that feeling man! Def swap heads if ya wanna run high boost! Get that cr down to 9:5 or 10:0 and put on some 10 psi and have fun! Also read mangled03's post about compression vs psi of boost! He has the same delima right now about upping the cr for daily driving vs. have more boost..
Good luck
Old Jun 11, 2010 | 09:55 PM
kwk174's Avatar
Well taking your advice. I went and got ahold of some ls3 heads for the head swap today. So ill be getting the new style intake and fuel system. This should lower the cr some. hopefully enough to run some reasonable lbs.
thanks for the help.
Will be putting a post of the head conversion.
Old Jun 14, 2010 | 08:18 AM
stoffer's Avatar
I paid my buck-o-five
the J&S vampire box will help you if you want to run boost on your set up, expecially with cast pistons
