twins are alive and well
Old Jul 20, 2006 | 05:04 PM
  #61
AintNoHo's Avatar
Originally Posted by dieselgeek
Real simple. The megasquirt has TWO separate injector drivers, so you can run eight injectors on one bank and fire them together; then we run eight separate injectors on the secondary bank.
-scott
So 16 injectors, right? 4 fuel rails? 2 fuel regulators, pumps, and tanks? Hope I'm not being too dense.
Old Jul 20, 2006 | 07:10 PM
  #62
kbracing96's Avatar
Gota love MegaSquirt and the power of DIY'er in large quantities , I've used it on two cars my self, but there both NA, but one will get a Paxton if the owner ever gets off his BUTT
Old Jul 20, 2006 | 11:01 PM
  #63
Stoichiometric's Avatar
Parish, if you need help with the crankcase evac you could call Andy at A&A Corvettes. He has experience with vacuum pumps and might be able to give advise for other systems too. Keep up the good work, the truck looks great!
Old Jul 21, 2006 | 12:15 AM
  #64
PappyDan's Avatar
Tribe Shaman
jim do you have any pics of your meth injection set up?
Old Jul 21, 2006 | 07:19 AM
  #65
Lord Aries's Avatar
I am just wondering if this is an issue for all of us or is it only Parish because his set up?
Old Jul 21, 2006 | 07:27 AM
  #66
TURBHOE's Avatar
so he is going to batch fire all eight at once instead of 4 at time like before?
Old Jul 21, 2006 | 08:55 PM
  #67
parish8's Avatar
single digit dreamer
i got a valve cover breather installed, got the intercooler pump wired up. decided it was time to go give it a little push and see if the oil leak went away. it didn't. the first time i got on it good it belched out a quart out the back of the motor somewhere, grrrrrr. time to pull the tranny and see where that oil is coming from.
since the oil leak doesn't seem to be coming from crank case presure that means the exhaust evac might be working. i will do some testing once i get the oil leak fixed.
i ran it up to 10psi and it pulled real hard, spool time seems to be about the same as the 88. it takes a little before it starts coming on but once it does it builds boost fast. , couple more days and maybe i can really get on it.
Old Jul 21, 2006 | 09:27 PM
  #68
Charged_5.3's Avatar
Make sure to record it
Old Jul 21, 2006 | 09:28 PM
  #69
Damn the hang ups
Old Jul 22, 2006 | 08:12 AM
  #70
Lord Aries's Avatar
Dont foget pics of your findings... Maybe it is the oil pressure sensor leaking?
