twins are alive and well
Old Jul 23, 2006 | 01:38 PM
  #81
TURBHOE's Avatar
i have the 5 book set from gm and that what is says. i said the same thing. something about the heat creating a seal or something. i could do a search from when i installed mine some one explained it.
Old Jul 23, 2006 | 01:44 PM
  #82
TURBHOE's Avatar
Originally Posted by ktmrider
There is a teflon type of insert on the inner part of the seal that is supposed to "melt" itself to the crank and seal better. Some say dry, others say wet install. Rumor is the teflon portion will not seat properly if coated with oil.
there ya go.
Old Jul 23, 2006 | 07:24 PM
  #83
parish8's Avatar
single digit dreamer
ok, i am stupid. i changed out the seal and decided to check the rear cover on the motor. it was finger tight , thats where all of that oil was coming from . now that is fixed. i went ahead and put in some synthetic oil. the leak is fixed.
got some good news, we went out and did some tuning. rolled into it a few times adjusting the fuel. eventualy went wot. the boost settles to 13psi wich is a little high. we tuned it to lower 11's a/f ratio and got slight amount of knock so there will be no more tuning till i get the meth hooked up. it looks like 13psi will be my minimum boost.
it is prety laggy, about the same as the pt88 i would say. in 2wd i was able to build some boost off the line and rip the tires for a few blocks the open wg's are prety loud. you can't really hear them slam open, the sound just gets louder and louder is all. we were next to a hotrod on the way home and i hit it from a roll and it was crazy loud next to another car. i think i hurt my ear. we made quite a few partial runs, a couple of full runs and drove it for 60+hard miles with no problems. i will have to wait till i get my meth back before i beat hard on it. by next weekend i hope to be pushing 15-18psi in 4wd with the gtech and see how it is really running , maybe even hit up the dyno
Old Jul 23, 2006 | 07:26 PM
  #84
parish8's Avatar
oh yeah, the valve cover breather is completely dry. the oil leak was not related to crank case presure and with no oil on the breather i think i am set for crank case evac.
Old Jul 23, 2006 | 07:35 PM
  #85
TURBHOE's Avatar
any videos?
Old Jul 24, 2006 | 12:40 AM
  #86
yea we need some videos now
Old Jul 24, 2006 | 11:46 AM
  #87
GenofiveO's Avatar
Hey jim did you get that issue fixed with the turbos making that sound? was that just the BOVs set to high or what??
Also I want to stop by sometime and check it out?
Old Jul 24, 2006 | 05:00 PM
  #88
parish8's Avatar
i haven't messed with it. they only make that sound from a low boost to leting partialy off. once i get the boost turned up in a week or so i will be backing those things off a little but it seems like the set screw is almost all the way out now.
you can come go for a ride whenever.i might be going to the car show this week.
Old Jul 24, 2006 | 05:03 PM
  #89
LesPaul's Avatar
Video!!!!!!video!!!!!!video!!!!!!video!!!!!!video! !!!!!video!!!!!!video!!!!!!video!!!!!!video!!!!!!v ideo!!!!!!video!!!!!!video!!!!!!video!!!!!!video!! !!!!video!!!!!!video!!!!!!
Old Jul 24, 2006 | 05:08 PM
  #90
parish8's Avatar
i will talk to kyle later but i dont know that there is all that much to see. i am learly to get on it for more than about an 1/8th mile till i get the meth back on.
