twins are alive and well
Old Jul 19, 2006 | 01:34 AM
  #51
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
congarts
Old Jul 19, 2006 | 01:57 AM
  #52
04Denali's Avatar
Well done,
Old Jul 19, 2006 | 07:08 AM
  #53
Do you have any pics of the fuel system? A link maybe?
Old Jul 19, 2006 | 07:11 AM
  #54
Wilde Racing's Avatar
How do I change this text
Originally Posted by parish8
yep,2 fuel cells, 2 fuel systems, 2 sets of injectors. it will be completely automatic, as the boost goes past 10psi the race fuel will start to flow out of the 2nd set of injectors and the pump gas fuel will be phased out. it isn't a new idea. it alows you to run cheap gas except when under lots of boost.
Are you still going to run megasquirts for both sets? Sounds like a good Idea. Plus having the second fuel cell with race gas makes the Race gas wet shot a bit easier to set up!
Old Jul 19, 2006 | 09:36 AM
  #55
maddboost's Avatar
What engine management system are you going to use for the dual fuel system. I think only BS3 supports it.
Old Jul 19, 2006 | 05:10 PM
  #56
parish8's Avatar
single digit dreamer
ms will do it just fine. there are 2 ve tables and you can assign them to diferent injector driver outputs.
i run a dry shot but yes you are right when i spray the nitrous i will add fuel thru the "race fuel" injectors.
what is soo great about the duel fuel set up is i will be putting around on 87 octane most of the time but when i floor it the good gas will phase right in. very little good gas will be used so i will be able to afford to buy really good gas like c16. it will truely be 1000+rwhp daily driver(no fuel change required)
Old Jul 20, 2006 | 12:53 PM
  #57
dieselgeek's Avatar
MS and the Rotary guys developed a very cool staged injection setup, a while back. I've used it on the one rotary I've tuned, and it is pretty slick.
Read about it here: http://megasquirt.sourceforge.net/extra/stagedinj.html
Old Jul 20, 2006 | 01:46 PM
  #58
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
Well, at least this stuff isnt getting complicated.
Old Jul 20, 2006 | 04:46 PM
  #59
AintNoHo's Avatar
I don't want to highjack the thread but I'm getting a little confused and intrigued by the handing off to the race injectors comment. Is it a supplemental cpu and injector setup like vortech or whipple (see pict below), or 16 injectors and 2 cpu, or 8 injectors and nitrous-like solenoid and fuel jets (without the nitrous) underneath or what? Can you give a brief discription?
Old Jul 20, 2006 | 04:49 PM
  #60
dieselgeek's Avatar
Real simple. The megasquirt has TWO separate injector drivers, so you can run eight injectors on one bank and fire them together; then we run eight separate injectors on the secondary bank. The software is set up so you can use boost (or TPS, or other variables) to decide when the secondary fuel kicks in. That secondary fuel has it's own "VE table" so you base it's fuelling off of manifold pressure (engine load) and RPM. So it's not like a piggyback setup, the megasquirt is in full control of both fuels. Tons of guys run it overseas, it's been out for a few years on the MS.
-scott
