TVS 1900 a little disapointed
Old Mar 29, 2010 | 06:02 PM
  #51
1989k1500's Avatar
Originally Posted by Atomic
do you have the floor shifter or push button? i believe the push button will stay locked if you stay at WOT
Mine would shift out at WOT and it was push button.
Originally Posted by AKlowriderZ71
GM says anything more than 1/4" difference in rolling circumference will kill t-case clutch packs, even if driven in 2 wheel drive.
It cant when the front diff isnt locked in. In 2wd the CAD will keep the pass side axle from being locked in, and the front diff is an open diff. So the front diff doesnt spin the driveshaft when you are not in 4wd, at all. Even if the autotrac case is slowly turning the front driveshaft it isnt going to matter.
Old Mar 30, 2010 | 06:30 PM
  #52
AKlowriderZ71's Avatar
11 Second Hall Moniter
Unfortunately, even though this makes sense, it isn't true. Not on a 4x4 equipped with the Auto 4x4 T-case. Don't believe me? Try this. Park your vehicle in 2 wheel drive. Get under it and try to rotate the front driveshaft. You can't. Clutch packs are holding it. Now put the truck up in the air, and rotate the rear driveshaft. You will see the front shaft turn also.
moregrip
Jul 26, 2016 11:21 AM
blown 04
Oct 2, 2015 07:33 AM
old motorhead
Sep 29, 2015 08:22 PM
97aztecgt
Sep 10, 2015 05:07 PM
