tvs 1900
Old May 18, 2009 | 05:59 PM
PSM's Avatar
PSM
Default tvs 1900
is there any glaring difference that would get me in trouble if i get a tvs 1900 kit made for a l76 and put it on my truck. I'd swap to l92 heads, but how would I deal with my return fuel system... any other problems people see, how about injectors?
Old May 18, 2009 | 06:19 PM
kbracing96's Avatar
Should be no problems I don't think. They use the standard Magnuson fuel adapters, so you can just get a return style reg assm like I did. Your injectors should work too, you might have to space the rails up, but no biggie.
Old May 18, 2009 | 06:25 PM
PSM's Avatar
PSM
That is good then. Any experience with l92 heads... do they give up a lot of low end because of the huge intake runners?
I thought of another thing, do the l76 trucks use a different TB? I have a tbss 90mm with a x link on the m112 now.
Old May 18, 2009 | 06:39 PM
BigCountryx's Avatar
Call Joe at Leftcoast. He has the answers to your questions.
Old May 18, 2009 | 07:23 PM
leftcoast32's Avatar
FormerVendor
We can set the whole thing up for you minus a tune, this is considered a Tuner Kit.
You should swap over to the LS2 Car TB because it wont have the problem with limp mode under boost that we see with the Truck Division TB. It will plug right in with the same connector you have now. I do think you have to have the x-module adjusted for the change is all?
Thanks for the vote of confidence!!
Old May 18, 2009 | 07:27 PM
PSM's Avatar
PSM
limp mode?
Old May 18, 2009 | 09:30 PM
FormerVendor
limp mode?
The computer reads the flutter of the throttle blade under wide open throttle and thinks it is uncommanded. It then shuts the truck down with no throttle responce, it will still idle. You will have to turn the key off for 30 seconds to reset it and then restart it.
Old May 18, 2009 | 09:33 PM
What can I say, You da man, lol. Seriously one of my best buying experiences ever. And get ready, instal time is near, I will be calling I'm sure
Old May 18, 2009 | 09:47 PM
FormerVendor
Thanks again! Call anytime you have a question.
moregrip
Jul 26, 2016 11:21 AM
blown 04
Oct 2, 2015 07:33 AM
old motorhead
Sep 29, 2015 08:22 PM
97aztecgt
Sep 10, 2015 05:07 PM
