STS tail pipe
Old May 12, 2009 | 09:13 PM
2ktransam's Avatar
Default STS tail pipe
Anybody ever tried buying the magnaflow 4" tail pipe and mating it to the STS pipe that comes off the turbo? I had a local shop do a 3" tail pipe witch is press bent so it's probably restricting me quite a bit. How much do you guys think it would help to step up to a 4" tail pipe?
Old May 12, 2009 | 09:19 PM
nonnieselman's Avatar
if your pushing alot of boost, then yea a 4" would help.
Ill be goin to 4" with the new turbo.
Old May 12, 2009 | 09:24 PM
2ktransam's Avatar
How much pipe do I need after the wideband sensor? I'm thinking about just hacking off the crappy tail pipe which would just leave the original STS pipe to see if it will help. I'm running 13psi right now so I think the tail pipe is probably choking it up.
Old May 12, 2009 | 09:27 PM
not too sure.. id run it about 10" after the turbo, and you need something like 24"? of tail pipe after? i cant remember, call the wideband company tomorrow and see what they say.
Old May 12, 2009 | 09:35 PM
BlownChevy's Avatar
blownerator
25 Year Member
I had one:
Old May 12, 2009 | 09:52 PM
BC,, yours is too clean under there
here is what i have now.
Its nice and quiet, but gotta go bigger when i go with more boost.
Old May 12, 2009 | 10:01 PM
BlownChevy's Avatar
blownerator
25 Year Member
LOL that pic was taken the same day I installed it.
Old May 12, 2009 | 10:02 PM
2ktransam's Avatar
I have a straight through magnaflow in front of the turbo. It killed all of the rasp but the turbo is still loud as hell. Summit has the 4" SS tail pipes for around $110 so I think I'm going to get one and have it mated to the STS pipe.
Old May 12, 2009 | 10:04 PM
UBLUZIN03's Avatar
I was gonna run a stock dmax tail pipe..
Old May 12, 2009 | 10:17 PM
silveradol33's Avatar
Butt mounts, lol. I would most deff go with the larger tail section it will really help out under more boost and it will sound and look really cool!
