turbo question
Old Sep 17, 2006 | 08:35 PM
beebelawn's Avatar
Default turbo question
I was curious what is the difference between a diesel turbo and a gas turbo or is there any?
Old Sep 17, 2006 | 10:15 PM
ogkevin13's Avatar
Banned
lil more info are you talking about just the 2 turbos in specific or the whole set up?
Old Sep 18, 2006 | 12:04 PM
duwem's Avatar
your a/r ratios will be significantly different because of the higher pressures in a diesel...some turbos are specifically built to be put on diesels, others on gas, but essentially they are the same.
Diesels have variable vane geometry, someone should put one of those on a gas engine.....
Old Sep 18, 2006 | 04:04 PM
beebelawn's Avatar
say like a turbo on a 6.5 diesel chevy not sure what kind it is. I know where i could get one cheap. the variable vane turbo didnt come out until 05 on lly and lbz chevy duramax.
Old Sep 18, 2006 | 08:05 PM
beebelawn's Avatar
the turbo is either a gm 4 or gm 8 whatever that means.
Old Sep 18, 2006 | 08:40 PM
TurboGibbs's Avatar
garrett makes the variable vane turbos. From what I hear they don't hold up well when you crank the boost up. That is just a rumor though.
Old Sep 18, 2006 | 09:02 PM
vanillagorilla's Avatar
Diesel turbos are designed to operate at much higher pressure ratios than most gas turbos. If you put the compressor maps for a 6.5 diesel turbo next to a turbo spec'd for a 6.5 gas engine you'll see.
Old Sep 18, 2006 | 09:11 PM
beebelawn's Avatar
where do i find compressor maps at?
5.3lSilverado
25
Aug 29, 2016 12:48 AM
08lambochevy
Aug 7, 2015 11:42 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
