Turbo guys, Air filter setups
Old Dec 22, 2010 | 10:06 PM
kazfan30's Avatar
Default Turbo guys, Air filter setups
Are you guys just direct mounting the filters to the inlets, or has this caused any higher IAT's?? I have seen some use 90 degree elbows but i kinda like the direct mount approach Pics welcome!!!
Old Dec 23, 2010 | 12:02 AM
Bluchevypick's Avatar
I have my turbo right behind my radiator and my filter is directly on it and my iats are good.
Old Dec 23, 2010 | 07:49 AM
Rick_Vor's Avatar
Direct to the turbos (see picture in sig). The Intercooler seems to take care of any minor AIT increases.
I've thought about adding 90's and some 3" to put the filters in a cooler location but my AIT's stay about 7-10 degress above ambient so I left them alone. I think it looks cleaner on the turbo.
Another benefit if you do add any kind of extension to the filter mount is it will give so some room to vent a catch can back into the intake track to suck up any blow-by.
Rick.
Old Dec 23, 2010 | 10:50 AM
foose04's Avatar
Here's my setup. I have since removed the catch can and just run open vented valve covers, works best for me. Also the filter is always cool to the touch now, when it was mounted to the turbo it was always very hot, with a 90 bend it was better, but still pulling air from the top of the engine bay. Here in South Carolina it gets hot, so I try to help the intercooler out as much as possible. You have to remember under boost these engine are taking in a LOT of air, I don't want my turbo acting as a heat extractor removing all that hot air.
Old Dec 23, 2010 | 06:13 PM
brent1976's Avatar
11 Second Club
Mine is similar to fooses setup. Mine has a 90* off of the turbo, and a 45* down behind the headlight. My cold side is black, so I bought some 4" diesel exhaust, welded it up, ground off the welds, and painted it to match.
Old Dec 23, 2010 | 06:16 PM
Atomic's Avatar
I have a gauge for that
I would be worried about driving in the rain with that setup with the huge puddles we have around here
Old Dec 23, 2010 | 07:47 PM
foose04's Avatar
My K&N stops just short of the fender splash guard so the K&N stays clean/dry. However if you plan to go into deep waters it would be a no go for sure.
Old Dec 23, 2010 | 11:32 PM
kazfan30's Avatar
Oh yeah I do like the set up going into the fender well that looks really nice and clean, plus drawing in that cold air can only help. Foose....that is one fine ride you have man..
Old Dec 27, 2010 | 11:18 AM
kalikid06's Avatar
I too attach the air filter directly to the turbo inlet - haven't had problem with IAT's
TAPyvehc93
Jul 23, 2017 10:54 PM
mhorn0817
Jul 8, 2017 01:54 AM
Go5.3tt06
Sep 12, 2015 09:29 AM
lxcoupe
Jul 21, 2015 02:12 AM
GM-only
Jul 19, 2015 10:48 PM
