Turbo blowing into supercharger-will it work?
Old Sep 7, 2005 | 06:13 PM
ASkipper's Avatar
11 Second Club
Default Turbo blowing into supercharger-will it work?
Some friends and I were talking today.We were all wondering what would happen if you say took a STS turbo with the T76 and set it up to blow through a supercharger say a Radix.What do you guys think would happen?
We are all stumped we really can't figure out what would happen.
Old Sep 7, 2005 | 06:24 PM
detentation alot of pinging unless you tune it and remove alot of timing ,4sure have to bulletproof the bottom end
since it looks like you have moooooooooney just get a 427 ci strocker
Old Sep 7, 2005 | 06:25 PM
sts--3995.00 + radix--4995.00 =8990.00 ??? 427 stroker +5995.00
Old Sep 7, 2005 | 06:31 PM
Mr. Sandog's Avatar
Something tells me that 427 is underpriced....I think you'd end up spending more than $8990.00 to do it right.
8ALTNG's Avatar
radix will not be able to keep up. It will be WAY to restrictive. Now maybe if you were going to use a t76 and then feed into a d-1 or f-1 procharger you might have something
Old Sep 7, 2005 | 08:00 PM
SVT_Scott's Avatar
Not to sure how well it would actually work?
Old Sep 7, 2005 | 08:04 PM
OLD BULL's Avatar
It's been done before, maybe not with that exact setup but I remember seeing it in Hot Rod magazine in the mid eightys. I believe it was Rick Doberton's Pontiac J2000. Try a google search on it maybe there is some info out there.
Old Sep 7, 2005 | 08:08 PM
OLD BULL's Avatar
Found some info. Twin turbos, twin blowers, and nitrous injected.
http://www.supercars.net/garages/ChevyRocks/32v2.html
Old Sep 7, 2005 | 08:41 PM
Crash Dummy's Avatar
Former Moderator :(
Almost every grayhound bus out there has a compound system under the hood, Big jimmy blower and a turbo. At least they use to not sure if they still do it or not
Old Sep 7, 2005 | 08:58 PM
storm5.3's Avatar
13 Second Truck Club
It's called a superturbo and I think Audi or VW will be coming out w/ one in the next year or two. It's set up like this the supercharger hits down low out of the range of turbo lag then at a predetermined RPM the computer tells a soleniod to "close the door" so to speak (bypass system) and the turbo takes over where the SC left off and viola...no lag, boosted perfromance down low and the top end to boot. Hence the name "SuperTurbo"...
