turbine A/R size?
Old Jan 20, 2010 | 04:36 PM
Badboy464's Avatar
Default turbine A/R size?
I am running a rear mount t-04e turbo with a .96 a/r. is that too big for my setup? would something smaller help out alot spool wise
or would I sacrifice my top end if I went with a .68 for example?
Old Jan 20, 2010 | 08:57 PM
Badboy464's Avatar
anyone?
Old Jan 20, 2010 | 09:17 PM
kbracing96's Avatar
I would run a .68 on your setup as well as wrapping ALL the exhaust piping with header wrap. That alone will help spool a lot.
Old Jan 20, 2010 | 09:27 PM
Badboy464's Avatar
I wrapped everything already and it still doesn't hit full boost til after 3500 rpm. Do you think a .68 turbine housing would choke my engine at higher rpms?
Old Jan 20, 2010 | 09:28 PM
Badboy464's Avatar
and how much sooner do you think it'll boost with that housing?
Old Jan 20, 2010 | 09:55 PM
2ktransam's Avatar
The .68 housing might choke it up a little on top but it will spool a lot quicker. I would think you would pick up 300-500 rpms on spool time. I think I have lost about 200-300 rpms on spool time each time I went to a bigger housing.
Old Jan 20, 2010 | 09:57 PM
2ktransam's Avatar
3500 is good for full boost. My truck doesn't hit 14psi until 5100 if I don't brake stall it.LOL
Old Jan 20, 2010 | 10:17 PM
GMCtrk's Avatar
Yeah, 3500 seems very good for full boost! Even synergy's twin turbo kit wasn't hitting full boost until 3200 rpm.
Old Jan 20, 2010 | 10:35 PM
Badboy464's Avatar
KB do you know where I can get one of these housings for a decent price in billings? I'm getting on the dyno at 10am tomarrow and it would be cool to see which one makes better power.
Old Jan 20, 2010 | 10:45 PM
2ktransam's Avatar
I don't think you are going to find a housing that quick and easy but I would put money on the bigger housing making more power. On your setup it shouldn't be a big difference so you could use the smaller housing for quicker spool up and lose maybe 20rwhp up top.
dsbodley
Nov 14, 2015 09:46 PM
GMCtrk
Oct 5, 2015 11:18 AM
old motorhead
Sep 29, 2015 08:22 PM
twake_410
Sep 25, 2015 10:09 PM
Closer_2001
Sep 24, 2015 09:15 PM
