Trick Turbo or Magnuson Kit
Old Aug 10, 2020 | 01:45 PM
pknowles's Avatar
Originally Posted by mchicia1
Thanks. Any pics?
I just looked at my line and it actually is two lines merging into 1 right before the compressor for the rear A/C.
They make AC hose tee's. Will require more work, but shouldn't be hard to make. I couldn't believe how easy it was to make my own AC line. Sucks having a $150 one use tool, but AC is worth it.
Old Aug 10, 2020 | 09:59 PM
ZO6Ted's Avatar
Who makes these line parts and tools?
Old Aug 11, 2020 | 04:43 AM
pknowles's Avatar
I got the hose ends and hose from coldhose.com, compressor adapter fittings from eBay, and Mastercool crimp tool you can get from a lot of places.
Old Aug 11, 2020 | 08:38 AM
Jonblarc7's Avatar
Did having a 1.5 body lift make it harder for your clearances. My 2014 has a 1.5 body lift and I always wonder if it will hurt me when I go boosted.
Old Aug 11, 2020 | 10:26 AM
pknowles's Avatar
Yes. Part number for the low pressure line for my 1500HD with a stock 1.5" to 2" body lift was the same for the 1500 without a body lift. In the end, I had to make my own intercooler brackets and AC line, everything else lined up fine because it's relative to the engine. To be fair, buying kits for 1500 trucks and putting them on HD or body lift modified trucks, I knew some stuff wound need some work. It really wasn't bad, just a few hours making brackets from aluminum angle and making the AC line took under an hour.
Old Aug 14, 2020 | 09:28 PM
mchicia1's Avatar
At
Here's my A/C line
Old Aug 27, 2020 | 01:58 PM
mchicia1's Avatar
Thanks for all the replies, decided to just put a 6.2 in. Keeping it simple for now. Found a 50k complete l94 shipped to my door for $3600, so I jumped on it.
Skerrt
Feb 7, 2018 09:28 PM
crashmymax
Jan 12, 2016 05:14 PM
LPCWS6
Mar 21, 2014 08:49 PM
1999Firehawkls7
Feb 11, 2014 12:06 PM
Th045
Apr 22, 2013 01:12 PM
