Trick turbo kit
Old Apr 21, 2013 | 10:40 AM
Th045's Avatar
Default Trick turbo kit
Is anyone running the trick performance turbo kit. I'm leaning towards buying the stage two kit and am wanting to run around 12 pounds and meth. Also when I first started this project I was going to go supercharger so I currently have longtube headers. 1 3/4" primaries with 3" collectors, will these hurt my performance with the turbo.
Old Apr 21, 2013 | 10:51 AM
Go back and study the pics of the turbo kit. Then look at the hundreds of pics of the turbo kits installed. Then come back and bump this thread.
Old Apr 21, 2013 | 10:55 AM
9 Second Club
Your going to lose the headers with a turbo kit. Call rick, and he will help you pick the right kit for your needs.
Old Apr 21, 2013 | 01:03 PM
Denali08's Avatar
You cannot use headers with Trick Turbo Kit. It comes with passenger side turbo manifold and you will need to re-install stock manifold on driver side.
Give Rick a call over the turbo kit stage based on your engine size and future goal.
I have stage-4 but wish I went with stage-5. I am running 18 psi.
Old Apr 21, 2013 | 02:10 PM
Th045's Avatar
Let me re phrase that I knew I couldn't run both headers but I didn't know if running the one header woul help or if it would be better to go back to stock manifolds on that one side
Old Apr 21, 2013 | 02:25 PM
darnie's Avatar
you will have to use a stock manifold.
Old Apr 21, 2013 | 02:45 PM
I just wanted you to study the setup's to see what is involved and how it works. KB's kits and Tricks are designed to work with manifolds which are good for well over 1000hp.
Old Apr 21, 2013 | 06:04 PM
Byrdman11's Avatar
Call Rick... shortie header is all you can run on the driver side. But run the stock manifold is better.
Old Apr 21, 2013 | 07:09 PM
jgb454ss's Avatar
The trick kits are very nice and fit very well. I have two kits and have no complains plus Rick helps u with any questions u may have..great customer service
Old Apr 22, 2013 | 08:05 AM
TrickTurbo's Avatar
Truck Sponsor
You will need to sale your headers.
The stock drivers side manifold is all you will need.
Give a call to go over your needs. I will need to know what your plans are for the truck. And the combination. Engine, cam, pulling not pulling etc.
This will get you the best kit for your application.
940-781-5204
Rick
