Trick turbo installation and review
Old Feb 18, 2016 | 08:06 AM
  #101
Choda's Avatar
Originally Posted by GXPJAY
What were your results? I made 540whp on a stock motor at 12psi so it is possible.
540!!! hot damn.
what turbo? 12 psi from our 70mm and 12 psi from an S480 BW is quiet different, lol
2wd/4x4?
93 pump?
meth?
Completely stock motor as in springs, cam... everything?
Old Feb 18, 2016 | 10:35 AM
  #102
crashmymax's Avatar
Tuner can't get a reading on MAF sensor. I did not cut wires just moved it over and plugged it back in. Any thoughts on what could be wrong?
Old Feb 18, 2016 | 10:40 AM
  #103
George C....'s Avatar
Formerly ScreamingL
Something many are no realizing here..On a gmt900 truck you need a 3 bar map to read boost...its not to run boost as tuning for boost is based off maf tube size
Next 550 isnt event close to linits of a stock motor
My old 5.3 with a cam made 575 on 9 psi on pure 93, not all turbos produce same amount of airflow so psi means nothing really
Next not all builds will equal same power, my 6.2 on 7 psi is right at 600 rwhp with a 75mm
Old Feb 18, 2016 | 10:41 AM
  #104
Formerly ScreamingL
When using hpt3.0 you need to properly setup the config files to log a maf
Old Feb 18, 2016 | 11:53 AM
  #105
crashmymax's Avatar
Will not having a 3 bar map installed affect maf reading at all? Also 2 bar will not work?
Old Feb 18, 2016 | 12:48 PM
  #106
GXPJAY's Avatar
Originally Posted by Choda
540!!! hot damn.
2wd/4x4?
93 pump?
meth?
Only valve springs, 72/75mm Turbonetics BB, 4x4 ran in 2wd on dyno of course through the 4L80E, 94 octane pump (we don't have 93 in Canada just 91 or 94) and with meth with the cutout open it's all part of the kit.
Old Feb 18, 2016 | 12:50 PM
  #107
GXPJAY's Avatar
I find it weird you would need a different Map sensor.
Old Feb 18, 2016 | 01:55 PM
  #108
Formerly ScreamingL
No to maf, if maf has its 3 wires then tell him to set up scanner right
Buy the zr1 3bar map...the guys talking in here about 2 bar are referring to a gmt800 trucks. The map you need is like 30 bucks from.
You only need the map to log boost in scanner...stock map quits at 120kpa which is around 3 psi
Old Feb 18, 2016 | 03:57 PM
  #109
crashmymax's Avatar
not sure I understand this my MAF has 5 wires. The tuner is done he does not have time to track down this problem so its up to me. with his HP tuner connected and the truck running he gets zero. with my diablo I 2 connected still getting zero. the computer recognizes that it is there because when the sensor is unplugged is it says failed. plug it back in and its not failed. what could I have done to cause this? checked all the wires for breaks all looks good.
Old Feb 18, 2016 | 04:07 PM
  #110
Formerly ScreamingL
Your maf has 3 wires the IAT has 2 wires
You have 3 wires
Ground
5v
Signal
Start probing to see what ya dont have
What have you done? Did you need to extend the maf wiring?
