Traction - Slicks/Radials
Old 05-23-2019, 02:38 PM
Superman956's Avatar
Cool Traction - Slicks/Radials
Guys need some help=
I will be running 16/18lbs of boost maybe 20lbs ( Tuner said I will be in safe zone still(>25))
What should I look for as far as size in track tires? 30,29,28"
What numbers do you also think I will dip into?
If I remove leveling kit will it make any difference at all?
Will my Nitto 420 even hook ;/ 2wd
Current mods - 2wd
- 5.3sbe 216/226 114 LSA Cam
-Precision Turbo 76mm
- 2 walbro 450 w/ 90# Inj - e85
- 4.30 Gears / 2 Peace DS
- Built 4L80 / 3600 stall
Old 05-24-2019, 01:14 PM
Ttt..
Old 05-24-2019, 01:22 PM
Resolute_welding's Avatar
So coming from the diesel world, a LOT of guys run 420s on their trucks and are pretty happy with them as a street/strip combo. I'd be a bit worried about your driveshaft. I don't get to go to the strip very often, but less rotational Mass is usually better. Find some stockers to run on the front and maybe like a 28" tall tire?
Old 05-24-2019, 03:27 PM
Thats what I was thinking just didn’t know to brake boost a little bit. I had found some drag radials 295/65/15 but it’s a 29.5
Old 05-24-2019, 03:30 PM
Are those going to clear your rear drum/disk? 15s are small
Old 05-24-2019, 03:34 PM
Mas far as driveshaft I have a metal 2 piece drive shaft. Upgraded as messing up my aluminum stock shaft
drum brakes idk if they fit
I have drum brakes I seen many run them but I have yet to try them on
chevysten
06-23-2011 07:38 PM
Hemi Killer
20
11-16-2004 01:50 PM
Last Call
07-15-2004 12:53 PM
O3GMC
01-30-2004 11:45 PM
Hemi Killer
08-06-2003 05:49 PM
Quick Reply: Traction - Slicks/Radials
