Thermal sensor placement for supercharger monitoring/tuning?
I have an IAT sensor in the intake tube logged thru the EGR position. Mainly wanted it to see CAI effectiveness and comparing pre-compressor temps to post-intercooler temps (IAT used for engine management).
Other temp sensors I have, which are logged thru external sensor positions on MVPI Pro, are in the A2W coolant system, which may be a good use for your thermocouples. You may gather some surprising data on efficiency of the system.
I suppose i could put a thermocouple in the cooling system then instead to see the real variations.
I hope I don't have to tear into my harness quite that much for my build... I am planning to put in a Deutsch bulkhead though to run most of my custom wiring through. When the engine is out, lots of room for activities under there.
I am doing the same thing!
I am doing the same thing! 47 Pin
It has different sized contact options so I can run bigger wires through if I want.
I haven't done any testing on any intakes. I will feed my Procharger from a semi-sealed box that occupies the same space as the factory air filter box
I figure it's never going to get cooler air than that
I have read several published white papers from OEMs that getting within 10-15° of ambient is the best you can reasonably hope for with an intake under the hood
Over the header intake is probably a little toasty tho lol
Since I had to move intake to the driver side for the KB inlet, I built my own. Original was a conical filter with a 'heat shield' that basically drew in underhood air. Current is a four sided box open to the front behind the headlight. At a stop, IAT1 will creep up a little as the box is not completely sealed from underhood air but soon as the truck starts moving, there is enough pressure in the box to keep the hot air out and IAT1 are pretty close to ambient. It is fairly crude made out of sheet metal and filter size is a bit limited. I have ideas of remaking with a 5" tube (current is only 4") and make a floor in the same area behind the light so to place a longer filter vertically.
lafnlt1
18
Sep 17, 2008 02:59 PM
