intake sensor for SD
Old Aug 31, 2008 | 01:00 AM
53RUSSELL's Avatar
Default intake sensor for SD
Where are you guys getting the intake sensor to read intake air temp? which wires do I need of the maf to connect to the intake sensor. This for turbo set up.
Old Aug 31, 2008 | 01:23 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Are you keeping the maf? I'd ditch it if I were you.
I bought a GM IAT sensor and plug from a 99 truck and spliced it into the harness. You can probably do a search for a post by me (or Parish8 for that matter) on wiring up a megasquirt -- I used the same IAT for my SD no-megasquirt build that I currently run.
Old Aug 31, 2008 | 01:39 AM
7845's Avatar
Banned
think the tan/gray wires. you can use the IAT sensor and plug from a Fbody. now if you can use the plug from the fbody and the sensor from a typhoon
Old Aug 31, 2008 | 08:23 AM
TURBHOE's Avatar
napa carries both. i used the sensor and pig tail from a syclone. if you look at the maf you can see the temp sensor and follow it over to the wires. you can also see where the wire go into the maf there is a small circle around the two wires you need. polarity does not matter, you can wire it either way.
Old Aug 31, 2008 | 09:56 AM
WJ MARK's Avatar
I bought an msd one
Old Aug 31, 2008 | 05:11 PM
53RUSSELL's Avatar
Do you have any part #. I tried going to napa and they weren't any help.
Old Aug 31, 2008 | 05:40 PM
1BADAZZSS's Avatar
I been watching this thread cause I am goin to have to do the same thing. Here is thread I found. Scroll down to the bottom of the first page for part#'s.
https://www.performancetrucks.net/fo...ion+iat+sensor
Old Aug 31, 2008 | 06:29 PM
TURBHOE's Avatar
ok found it. su107 at autozone and 534-46 for the pig tail. http://www.autozone.com/R,1018119/st...ductDetail.htm
http://www.autozone.com/N,15900112/s...eResultSet.htm http://www.napaonline.com/MasterPage...erature+Sensor
or post 10 from the above link
4513K72 from McMastercarr.com for the bung!
Old Sep 1, 2008 | 01:33 AM
53RUSSELL's Avatar
Originally Posted by WJ MARK
I bought an msd one
I looked on Summit under MSD and didn't find it. Could you give modle # or a link to it.
Old Sep 1, 2008 | 01:35 AM
53RUSSELL's Avatar
Thanks 4.8t for the modle #s
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
Fast86z
Aug 23, 2015 12:35 AM
Suburban2500
Jul 14, 2015 02:10 AM
jrplz
Jul 9, 2015 12:07 AM
