Talk about prochargers
Old Feb 9, 2016 | 05:38 PM
  #141
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
i never ran mine with the stock tensioner went striat to a HD tensioner
i made 9psi on a 3.85 pulley with my 6 rib setup on my heads cam LQ4
hopefully you don't have belt issues like i did
Old Feb 9, 2016 | 06:08 PM
  #142
MikeD.'s Avatar
lq9, Tv2 cam (232/234 .600/600 112lsa), longtubes, nnbs intake w/87mm tb. I talked with procharger, and was told 4.25 would get me 8psi? I also have a 3.70 that came with the kit when I bought it used.
Also, when you guys say HD, which are you referring too. First thing that comes to mind is like 2500 HD truck tensioner lol
Old Feb 9, 2016 | 06:13 PM
  #143
MikeD.'s Avatar
Just realized I follow you on IG..
Old Feb 9, 2016 | 06:48 PM
  #144
Vortec350ss's Avatar
I dont see that pulley making 8 PSI if you still have the stock balancer. Your cam will bleed off too much boost. It has 9* of overlap
Frankly the 3.7 with the 6 rib will probably slip, but I'd probably run it. Depending on whether and where you shift you will be in the 10PSI ball park. Definitely get the HD tensioner. Kurt can get you a part number.
Old Feb 9, 2016 | 09:57 PM
  #145
MikeD.'s Avatar
Frankly the 3.7 with the 6 rib will probably slip, but I'd probably run it. Depending on weather and where you shift you will be in the 10PSI ball park Definitely get the HD tensioner. Kurt can get you a part number.
Currently shifting about 6200. And what are you thinking with the 4.25, maybe 6/7psi? Or maybe find a 4.00 and be right in the middle? And how do I get ahold of curt?
Old Feb 9, 2016 | 11:39 PM
  #146
lol im KURT
you need a magnacharger HD tensioner look around i bought mine used on here they pop up every so often
i don't see you making 9* or 10* with a 4.25 3.70 will probably get belt slip like rob said smallest i ever went with my 6 rib was 3.85 and was shifting at 6200 iirc
Old Feb 10, 2016 | 12:13 AM
  #147
MikeD.'s Avatar
lol im KURT
Ohh.. Haha, well I originally was only shooting for 6/7 psi. I'm only looking to break the 500s, and maybe dive into the 11s. The truck runs 12.55 @ 109 right now, NA, so I'm hoping a few psi will make it happen. I'm going to run the 4.25 and see what happens
Old Feb 10, 2016 | 08:44 AM
  #148
George C....'s Avatar
Formerly ScreamingL
Odd how a 3.7 will have slip but my old 3.2 didnt slip
Old Feb 10, 2016 | 09:03 AM
  #149
Maybe it wont... I dont know.
You also had a P1. That took a lot less drive power to spin. Apples to Oranges.
Old Feb 10, 2016 | 09:10 AM
  #150
Formerly ScreamingL
Units are similar, difference is size of belt and tension applied...my belt was sized to where i had to walk the belt on the crank pulley
