Starting my Trick Turbo install
#51
That much boost the gate is fine.
Now if you were trying to run 4-6 psi you might need s larger gate. Gate is just a bypass vent. The higher the boost the less you want to bypass. At 20 you are coming to the end of that turbo.
Have you tried higher?
The standard Borg t4 83 would give good flow and less back psi.
It's a large housing and large ar potential.
Requires a larger down pipe config.
#53
Whistle Truck Guy
Rick I've had it as high as 22psi but IAT's were almost 160. ECM was pulling 3* of timing for KR and 3* of timing for IAT. So she was a bit out of her element.
#54
Choda
Jan 22, 2026 02:03 PM
lxcoupe
Jul 21, 2015 02:12 AM
