Starting my Trick Turbo install
Old Sep 5, 2016 | 07:04 AM
  #51
TrickTurbo's Avatar
Truck Sponsor
That much boost the gate is fine.
Now if you were trying to run 4-6 psi you might need s larger gate. Gate is just a bypass vent. The higher the boost the less you want to bypass. At 20 you are coming to the end of that turbo.
Have you tried higher?
The standard Borg t4 83 would give good flow and less back psi.
It's a large housing and large ar potential.
Requires a larger down pipe config.
Old Sep 5, 2016 | 07:47 AM
  #52
Atomic's Avatar
I have a gauge for that
Go ahead and put the big turbo on, you will sooner or later eventually :p
Old Sep 6, 2016 | 10:40 PM
  #53
Whistle Truck Guy
Rick I've had it as high as 22psi but IAT's were almost 160. ECM was pulling 3* of timing for KR and 3* of timing for IAT. So she was a bit out of her element.
Old Sep 7, 2016 | 05:45 AM
  #54
TrickTurbo's Avatar
Truck Sponsor
Yea time for a bigger turbo.
Old Sep 7, 2016 | 10:39 PM
  #55
Whistle Truck Guy
Is the 83mm Borg exhaust housing a 4" outlet?
Old Sep 7, 2016 | 11:00 PM
  #56
TrickTurbo's Avatar
Truck Sponsor
Bigger turbo will need bigger down pipe.
3.5" is What we normally send with t4 borgs.
Old Sep 7, 2016 | 11:09 PM
  #57
Whistle Truck Guy
I have a 4" downpipe for the s480 with the 96mm exhaust wheel, just curious if the outlet flange is the same for the 83mm exhaust wheel.
Old Sep 7, 2016 | 11:11 PM
  #58
TrickTurbo's Avatar
Truck Sponsor
Yes as long as it's a t4 Borg.
Choda
Jan 22, 2026 02:03 PM
TAPyvehc93
Jul 23, 2017 10:54 PM
TAPyvehc93
Aug 21, 2015 05:19 AM
Jake75
Jul 22, 2015 09:20 PM
lxcoupe
Jul 21, 2015 02:12 AM
