Starting my Trick Turbo install
Old Dec 23, 2013 | 10:34 PM
  #31
oakley6575's Avatar
You should be able to modify the tables correctly if you do it at the pump. I added a programmable gauge to my truck that works great. You just tell it when it is empty, then fill the truck up and tell it that it is full. It has presets built in too but none of them match our senders
Old Jan 26, 2014 | 10:23 PM
  #32
Whistle Truck Guy
Just a little update, in case anyones looking... Gotta backtrack a bit, came into a bit of extra cash and decided to do a cam swap instead of leaving the little 4.8L all stock. Ordered a custom cam from Bullet, 227/228, .605"/.605" on a 115 LSA, 110* ICL. Hopefully the stock bottom end will hold 650-750 ponies for long enough to let me save up enough bread for a forged 370. If it lasts long enough and still hasn't cratered when the new motor arrives, the boost will be increased substantially. I've heard of these little motors holding up to a ridiculous amount of power... Wouldn't hurt my feelings any if it lived for a quite a while making as much power as 25+psi would make. I'll try and make sure I have the GoPro going any time I take a cruise if I do get to crank up the boost on the stock rotator. Damn sure don't want to let a spectacular explosion go unrecorded. LoL
Old Jan 27, 2014 | 10:05 PM
  #33
chumba's Avatar
Did you ever get your fuel gage to work? I got mine working.
Old Jan 28, 2014 | 07:14 AM
  #34
silver-mod-o's Avatar
Hunt&Fisherator
If you are considering that much boost on stock pistons you need to pull them, re gap the rings and have them coated... In all honesty I wouldn't go thru that trouble if this is an in between engine. Just run it on 10-15psi until you have funds for the engine you want. Have it built, then pull your 4.8 and keep it for backup. Honestly. I don't know of a single "built" engine that's been subjected to boost that's lived as long as they said it would for various reasons.
Old Jan 28, 2014 | 08:16 AM
  #35
Atomic's Avatar
I have a gauge for that
I ran a smaller cam than that on my 402 0_o
Old Jan 28, 2014 | 12:06 PM
  #36
Whistle Truck Guy
Running it on about 15psi is the plan, but I hadn't thought about pulling the 4.8 to keep as a backup. Pretty good idea.
I also thought the cam was a bit large, but that's what the guy at Bullet recommended when I told him about my setup.
Old Jan 28, 2014 | 01:22 PM
  #37
oakley6575's Avatar
Yea I'm with atomic. I bet you will like the truck a lot more if you run a much smaller cam. Btw, 15psi on a 4.8L is fun
Old May 27, 2014 | 11:17 PM
  #38
Whistle Truck Guy
Bringing the thread back... Finally getting some disposable income that I can use on the truck. Anyone have any suggestions on a wideband kit? Or gauge? Is all I need just a gauge and sensor or something more? The truck will run on e85 if that matters. Thanks for any help.
Old May 28, 2014 | 06:38 AM
  #39
Atomic's Avatar
I like the NGK wideband....the gauge sucks but the analog output and sensor is very nice.
Old Jun 15, 2014 | 12:31 AM
  #40
Whistle Truck Guy
Going with a bit smaller of a turbo for a while till I can get a good stout 370 built. God forbid the amount of hell I'm going to catch for this lol... Ordered a cheap 76mm ebay turbo that looks like its going to work pretty well with the cammed 4.8L... I wouldn't be going cheap like this, but, as usual in the life of a farmer, this year's income wasn't quite what I was hoping for. Better than going deeper into debt... But not good enough to afford the use of top brand name components at this time. From what I've heard, the turbo I ordered is no slouch, and should work quite well for what I'm doing.
