So we have a vent for the procharger :P
After a little thinking, a buddy, me and pops, came up with this.. It has a 1psi relief spring in it, is baffled.. This is it.. Did a lil threading, cutting on the lathe.. Just pulled the blower back off the truck to pressure test it, with freon and a sniffer. All is good, clean it off. I did not want to put anymore then 10 psi into the unit. But the sniffer did not pick up any freon leaking out of the unit.. So this tells me it is making a decent bit of pressure.. After inspection of the blower, with out a doubt still that damn shaft seal. Hope the vent stops it. Gona find out soon..
Lmao you guys are to much may you rot in peace. The valve did work some.still have a small issue. It is now puking the slightest bit out of the breather. Going to up the valve to one with a bigger spring.might solve the prob Tom is another day. But def a improvement.
carid
Oct 1, 2015 09:22 AM
