Radix J Tube... 5 bolts or 6??
Old Feb 24, 2006 | 01:53 PM
JimS's Avatar
Default Radix J Tube... 5 bolts or 6??
DrX posted a pic of his Radix off the truck and it had 5 bolts holding the J tube on.
I've finally managed to get the middle bottom back bolt out and I've bent up a 12mm box end wrench to fit under the cowl so I can get the top bolts out but...
If there is as 6th bolt, in the back, bottom, under the j tube then I'm just screwed as relates to getting the j tube off the truck with the sc still in the truck.
So, what's the word? 5 or 6 bolts on the back of the Radix J tube?
Thanks, Jim (if there's five I'll have the 90mm tb up & running in just a few days as my machinist genious friend make time to weld the corner on the flange, make a hole and elongate a couple other holes... PLEASE tell me there's 5 )
Old Feb 24, 2006 | 02:03 PM
BlownChevy's Avatar
blownerator
25 Year Member
Old Feb 24, 2006 | 02:19 PM
JimS's Avatar
Originally Posted by BlownChevy
..5..
YESYESYESYESYESYES!!! The definitive word from the guy what knows!!!!! FIVE!!!!!!
This sounds dumb I know but I achieved a real thrill by getting that job done on my own. It was a bitch and by god I did it. I didn't have to go for help. I've never been very "handy" but I did it and that's a big deal.
Now to get the j tube off there and get it altered.
Thanks Brian! Jim
New Question: Which Perma Tex product will work the as well as the Loctite 510 that is recommended to seal the J tube back onto the sc.
Old Feb 24, 2006 | 02:29 PM
BlownChevy's Avatar
blownerator
25 Year Member
Thanks Brian! Jim
Get the Loctite
Old Feb 24, 2006 | 03:23 PM
5.7's Avatar
5.7
hehe a real back breaker i cant believe you did it
heres a couple tips for ya bro it will help with the install 1) open up the the hood and remove the bolt from hood support and put it in the other hole see pic.. 2) unbolt fan remove and then youll have space to put your feet.
Old Feb 24, 2006 | 07:54 PM
JimS's Avatar
Get the Loctite
GOT the locktite.
My machinist says he'll be able to weld on the "EAR" and port the j tube by Wed for sure. Then the next week the Pacesetters w/cut out and wb guage will get installed.
Following that I can go see Zippy to install the heads, cam, meth kit, radiator, mjhowards cool extra large heat exchanger, and put a bad *** tune on it all.
Old Feb 24, 2006 | 08:28 PM
JimS's Avatar
5.7... thanks for th tip!
Brian.... You mentioned in another thread that the Corvette 90mm tb had a groove machined in for a gasket but mine does not (ordered the part # in your thread). I'm wondering if I can just seal it with the Loctite 510? Or would making a gasket be better?
When using the 510 is it spread all over or is it best to lay down a bead and let it spread from the pressure of bolting the part on? Thanks, Jim
Old Feb 24, 2006 | 09:09 PM
krambo's Avatar
lay a bead, don't smear.
I currently am using just the loctite on the TB but now have gasket material that I am cutting up. Got it from summit. The TB sits fairly tight on the flange but a more forgiving gasket seems to me to be a better choice.
Old Feb 25, 2006 | 06:53 AM
JimS's Avatar
I think I'll get some gasket material.
Old Feb 25, 2006 | 09:40 AM
DrX's Avatar
DrX
The groove for the seal can be machined into the flange as on the LS2 intake.
Attached Thumbnails Radix J Tube... 5 bolts or 6??-ls2-intake.jpg   Radix J Tube... 5 bolts or 6??-throttle-body1.jpg
mikeyjm1
17
Oct 29, 2015 11:04 PM
Justin87gn
Sep 10, 2015 12:06 PM
chvy=power
Sep 8, 2015 11:06 AM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
