Radix
Old Dec 16, 2006 | 04:13 PM
  #21
GT2-3 specs are 207/220.571/.578 118.5 and GT-7 specs are 208/230.541/.546 121.I run a GT2-3 with 1.75 rockers.The cam makes power from about 1500rpm to about 6600rpm.My low speed performance is like 396 big block in a Camaro,I can break the tires loose with ease.
Old Dec 16, 2006 | 09:07 PM
  #22
Allen set me up with a Comp Cam 224/224/581/581/115 lsa for my LQ9 6.0L. He says it is a great reliable cam combo for the Radix. Not too big and not too small. Big power gains without sacrificing low speed drivability or idle issues.
Your 3200 stall sounds way too big for a twin screw S/C setup.
Top stall speed recommended for Radix applications is 2800. That is if you still want good everyday driving results.
I will be using a Vigilante 10.5 tripple disc rated at 2400-2600 stall. This converter was recommended by FLT for my application.
Just thought I'd share my custom cam profile and TC stall speed with you.
Take the info as you will.
Good luck for whatever you decide.
Jim
Old Dec 16, 2006 | 11:07 PM
  #23
nice_n_lo_silverado's Avatar
Jim
Thanks. I explained everything to PI and they said it was fine. I am not driving the truck every day. I have an 05 escape for that.
Old Dec 16, 2006 | 11:08 PM
  #24
By the way the cam allan recommended has more lift but less duration than the Futral one
Old Dec 17, 2006 | 12:05 PM
  #25
onebadrubi's Avatar
why woudl he set up the same int/exh duration cam for a supercharger setup?
Old Dec 18, 2006 | 12:22 AM
  #26
" Allen set me up with a Comp Cam 224/224/581/581/115 lsa for my LQ9 6.0L. He says it is a great reliable cam combo for the Radix. Not too big and not too small. Big power gains without sacrificing low speed drivability or idle issues."
What times are you running with that cam and what pulley is on your radix?
Old Dec 18, 2006 | 11:45 AM
  #27
GMC_DUDE's Avatar
Originally Posted by BlownChevy
There are a few guys that have painted their radix superchargers, the only problem is it will void the warranty on the blower.
Just curious, why would paint void the warranty? Only thing I can see is if someone tried to paint the bypass linkage and gummed it up. Or maybe got paint in some of the orifice holes.
Old Dec 18, 2006 | 12:52 PM
  #28
James B.'s Avatar
If you could figure out some bypass plumbing you could mount a Whipple 140AX with 7.5/16" drive on that manifold, those are black already. The downside would be that you'd end up with the ultimate supercharger setup.
bagged7104SS
Sep 24, 2015 08:42 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
Dave95Formula
99
Sep 14, 2004 06:11 PM
Fun Guy
80
Dec 13, 2003 08:38 PM
