questions on Radix
Old Nov 23, 2007 | 08:07 PM
seadoo's Avatar
Default questions on Radix
okay, I am looking to get a radix in the future. I was considering a STS, but just yesterday I had to back my truck so far down the bumper was under water and the muffler was half in the water just to put my boat in the water, thanks to the dropping lakes here in FL. so my only other option is a Radix which I have always liked anyway. I want to know if the radix on a stock 5.3 with stock boost is load depended like the STS. meaning while im towing with the cruise on, if the trucks comes out of OD looking for a little more power, the Radix will start coming into boost a little bit before the truck will decide it wants to drop down to 2nd at 70mph. I hate when it does that. In other words, the boost will begin to come on sooner with the load compared to no load correct?
Old Nov 23, 2007 | 08:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I have never towed but I'd say a lot of that depends on the tune as well. I can go up some pretty long/steep inclines without downshifting at all.
Old Nov 23, 2007 | 08:14 PM
Casey2323's Avatar
You can go to the GM dealership and Get a Radix installed with a Full Factory GM warranty... I understand what your asking... but Your not going to have to make the truck Kick down to see boost ... I have done the Blower then turbos... Daily driver killer power and drive it anywhere Radix is without a Doubt the awnser... with alot of new models able to build 600+ HP ...
Old Nov 23, 2007 | 09:02 PM
seadoo's Avatar
good, thats what I wanted to know. the truck does not have to kick down. one last question... when just cruising on the roads, and not in boost. do you still get the same mileage you had before the blower??
Old Nov 23, 2007 | 09:06 PM
WJ MARK's Avatar
Have you thought about the Trick Front Mount? I tow with mine and works great! don't need to worry about sucking in water either.
Old Nov 23, 2007 | 09:07 PM
seadoo's Avatar
considered... but was looking for a true bolt on kit
Old Nov 23, 2007 | 09:11 PM
BlownChevy's Avatar
blownerator
25 Year Member
Then you have made your mind up Now call one of the sponsors and get it ordered up!
I forgot to ask, where are you located?
Old Nov 23, 2007 | 09:27 PM
GMC_DUDE's Avatar
IF you can behave yourself, then yes, the mileage is essentially the same, some even get better. HOWEVER if you're like most of us, you'll end up doing a lot of and mileage will decrease accordingly.
Old Nov 23, 2007 | 09:35 PM
seadoo's Avatar
thanks guys... im in Sebring, FL
Old Nov 23, 2007 | 10:03 PM
Casey2323's Avatar
I ran a whipple with No I/C and 7psi for 80,000 miles truck would run low 13s and still over 22mph on the highway... 02 RCSB 2wd
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
