Purchased Trick turbo kit. 09 4.8L Now for the help
Old Nov 8, 2013 | 10:33 AM
MarkGMCCrew's Avatar
Registered User
Default Purchased Trick turbo kit. 09 4.8L Now for the help
Hi Im new to this forum but it looks like the best place around for this type of work.
I have a backround building small and big block chevys for truck pulling, motor swaps and car restoration. But this is for my DD, and I dont have any turbo exp.
So about the truck Its a 09 CC gmc 4x4 1500 w/4.8 non flex fuel as far as I know. I want more power so my Trick perfomance kit is on its way from Rick!
Just wondering from everyone elses experience what else I am going to need, I have read all the other threads but none are exactly the same and I would like this to go as smoothly as possible, Rick has suggested Injectors but im wondering what HP i can get for a complete stock fuel system? and any other help/ advice would be greatly appreciated!
Old Nov 8, 2013 | 10:45 AM
Registered User
Also I forgot to add It is a stage 2 Kit
Old Nov 8, 2013 | 03:21 PM
Registered User
If it is mandatory to do injectors, all I need is a part number or recommended injectors.
Old Nov 8, 2013 | 04:16 PM
black00chev's Avatar
Slowest turbo build ever!
If non flex fuel you will want a 255lph or better fuel pump and also some 42# or bigger injectors. This all depends on how much power/boost you want to make.
Old Nov 8, 2013 | 04:25 PM
Noah Burns's Avatar
you'll definatly need injectors and a fuel pump, stock stuff won't support boosted power levels
Old Nov 8, 2013 | 04:56 PM
9 Second Club
I would suggest a boost controller. You could also push the envelope on the stock fuel system by adding a methanol kit.
Old Nov 8, 2013 | 08:45 PM
ZO6Ted's Avatar
Without a pump and inj you are likely limited to 4-5 lbs or so. Do a Walbro pump as said above and 42's or even 60's. Good luck!
Old Nov 8, 2013 | 08:49 PM
Registered User
EV6/USCAR 30507-8 50lb these are the injectors I am looking at are they a direct fit or do I need to modify
Old Nov 9, 2013 | 03:08 AM
roland1's Avatar
Give "fuel injector connection " a call and tell them your goals and what truck you have. And they'll set you up with the right injectors.
That's what I did.
Old Nov 9, 2013 | 07:13 AM
whippled 8.1l build's Avatar
if this is your dd your prob gonna be staying under 10 psi and if thats your goal you can go stock 8.1l injectors and be goood with the fuel pump you have.. going over that youll need to go bigger on injectors and fuel pump
