Purchased Trick turbo kit. 09 4.8L Now for the help
Old Nov 10, 2013 | 11:02 AM
  #21
Choda's Avatar
I read here that they will have no prob supporting 500 wheel. That's the end goal for me and I think these 60s would allow for more but NEVER limit your fuel system. Try to stay one step ahead.
Old Nov 10, 2013 | 12:02 PM
  #22
MarkGMCCrew's Avatar
Registered User
Great to know! Thanks
Old Nov 10, 2013 | 12:03 PM
  #23
Registered User
That's my current goal as well, how much power did you make with your stock fuel system?
Old Nov 10, 2013 | 01:14 PM
  #24
Choda's Avatar
It's in my sig. Do not take offense but Sounds like u need to do some serious reading on here.
Old Nov 10, 2013 | 01:37 PM
  #25
Registered User
None taken, and I can't see your sig on my phone.
Old Nov 11, 2013 | 05:19 AM
  #26
Registered User
NOW, I see! those are some good numbers!
I am picking up my injectors and wide band this week and hopefully the Trick kit is in the mail by the end of the week.
Any advice on Wide band sensors and guages?
Old Nov 11, 2013 | 11:39 PM
  #27
11silverado's Avatar
Originally Posted by MarkGMCCrew
Thank you!
So does anyone know what stock e85 injectors are for Lb/hr? I see that you are maxed out at 8psi I would like to make sure my 50's will be big enough
i have stock flex fuel injectors that came stock on my 6.2 silverado.
they flow 54lb/hr and i have pushed all way to 11.5 lbs on an 80/83 BW trick stage 5. 650rwhp + with proven mph at the track ..injectors will flow but the flex fuel pump is the first issue. when i change them im going with the walbro 450 and the 80lb injectors...I will also advise to run METH..I run boost ref meth all the time (turned to low setting)
if you are planning on going 600rwhp or less the stock flex fuel are plenty...
Old Nov 12, 2013 | 11:30 AM
  #28
Registered User
It was a real pain trying to find flex fuel parts here, so I called fiveomotorsports and he hooked me up with some 52lb injectors. I am now searching for a fuel pump that will fit in place of the stock unit.
Old Nov 12, 2013 | 05:38 PM
  #29
ShredSled's Avatar
Call Aeromotive.
Get yourself a hotwire kit as well.
Originally Posted by fastnblu
I've got 42# on my brain for some factory Chevy application. I thought flex fuel inj's were 42#. Or are the 8.1's? Somebody on here knows.
But maybe this will help.
http://www.precisionturbo.net/images...large/42-2.jpg
The 8.1 "Marine" injectors are 42#. That's what I have, and they are direct fit for height and plug for gen III truck. 8.1 reg. Kodiak are less, like 30...
Old Nov 13, 2013 | 05:20 AM
  #30
Registered User
[QUOTE=ShredSled;5162005]Call Aeromotive.
My only issue with this is, do I need a fuel pressure regulator with a hot wire kit since my system is returnless? or is that only if i go with an inline pump?
